International Pickup
   / International Pickup #1
Joe_W
Greenville, Ohio
2001 Kubota B2910
Hello,
You guys are so good at finding information, I thought I would try this one on you. I just bought a 59 A-100 International Pickup with the BD220 6 cyl engine and 1 bbl carb, and the accelerator pump in the carb does not work, which causes it to stumble badly when pulling away from a stop. My question is do any of you know where I can find carb info and maybe a blowup of the carb itself. I also can't find any markings on the carb to tell me which model it is. I've searched all the obvious combos of IHC, International, etc., but I've not been able to find any useful info.
Thanks for any help,
Joe W.
   / International Pickup #2
Back in my youth I had some Internationals , two seventeen hundred two tons and a one ton pickemup.
The biggest problem with them was you had to have a serial number off the chassis to get the right part. It seems International would pick the cheapest vendor each and every time. So you could have two trucks of the same model and year and some of the parts wouldn't interchange.
But darn, they'd run forever it seemed, just when they broke, it hurt the pocketbook bigtime.
   / International Pickup #3
This may not be very helpful but here it is anyway. There is a place in California that rebuilt an old two barrel carburetor for me about fifteen years ago. Of course I do not know the name of the place, my local auto parts store recommended them when I had an oddball carburetor that needed to be rebuilt. I had to send mine to them and they worked on it for about a week and sent it back. Maybe a web search will turn something up. Now I am enough of a gearhead that I would just disassemble it myself. If you totally destroy it you can probably get another one from a junkyard anyway, and that one may work better anyway. I would hazard a guess that your old carburetor is not terribly complicated anyway, but only you know if you are up to taking it apart so you can watch the springs fly around the room/w3tcompact/icons/shocked.gif .
   / International Pickup #4
Have you tried your public library for older Chilton manuals?
Other then that, this <A target="_blank" HREF=http://www.vapinc.com/>link</A> might be a good starting point.
How you been to any parts stores yet (NAPA, for example)?
Those old International pickups are to the point now to be collectables. Of course, some of the older farmers probably still run trucks of that vintage. I've seen a number of farm trucks in southern PA of 50's vintage.
Reckon you'll probably end up with a newer carb. Finding a rebuild kit might be a tough chore.
By the way, those old engines really need leaded fuel. You can get the additives...used to be able to, anyway.
Internationals were really tough trucks, but they were real bad on fuel consumption!!!
   / International Pickup #5
I cannot help you any,but when you said International truck,I cannot help but think of days gone by when a truck was a truck,like the old Dodge Power wagons/starters on the floor,parking brake next to the gear shift/throttles/gears so low 45 mph sound like a hundred mile an hour.trucks that were designed for work and not made as a touring car./w3tcompact/icons/smile.gif
   / International Pickup #6
>>I've searched all the obvious combos of IHC, International, etc., <<
I THINK they went through buy outs, and name changes ..... As such, I think their last name was "Navistar". I doubt that will help much..think the others have given you better info..but I just thought I'd put that out there to you just in case.
Just checked...can go to <A target="_blank" HREF=http://www.navistar.com>http://www.navistar.com</A> and maybe find something? Good luck
Richard
   / International Pickup #7
I just happen to have my <font color=red>Harvester Highlights</font color=red> from the <font color=red>International Harvester Collectors</font color=red> sitting here... Here are some ad's from the magazine...
<A target="_blank" HREF=http://www.redpowermagazine.com>http://www.redpowermagazine.com</A>
"Classic Tractors and Trucks"
shop: 218-493-4288
http://www.ihcollectors.org
One of those should get you started in the right direction...
   / International Pickup #8
The accelerator pump probably has a worn out diaphragm. When you can't find a replacement you have to make one. I did it once with duct tape for a '37 Nash windshield wiper motor.
I thank all of you for your replies. I intend to repair this carb, but something tells me that I have a part or two missing. I pulled the pump diaphragm out of the carb, and I don't see anything happening to the linkage in the bottom of the diaphragm chamber when I move the throttle linkage. This leads me to believe that there is something missing internally with the diaphragm linkage. The diaphragm itself appears to be OK. I want to tear it down, but first I want to find the model number of the carb and try to get a kit for it so I don't have to make the gaskets.
I tried all of these links prior to posting this except for the carb shop in Fletcher, Ohio which is about 35 miles from here. I was hoping that he would have something to help me, but it appears that he only deals in tractors. I'll call him to make sure though.
Thanks again for your suggestions and responses, I appreciate all your help. I tried to post a picture with the original post, but it didn't work. I'll try one more time.
Joe W.
   / International Pickup #10
Go Joe! Memories... I had an old "Cornbinder" (IH) 3/4 ton with 4 on the floor, PTO winch, 4x4 etc. It had a REAL truck V8 (red lined at 4000) not some automotive V8 with different accessories. It started life as a cab-chassis unit that was used in filming the movie "The Greatest Story Ever Told" and was sold at 8 mo of age to an artist in Leucadia, CA who built on a home brew RV complete with walk through from the cab. It looked like a cross between a field ambulalnce and a Brinks truck. He shipped it overseas and did Europe in it. It had bars over the windows that wre big enough for unauthorized entry, locking shovel holders, ladder to the walkable top, two potable water tanks, a built in 5 gal white gas tank for the Coleman stove and lanterns and on and on. Cruised the great American south west in it and Baja California as well. Under the seats-four-people couch there was a spares bin stocked with U-joints, clutch disk, brake shoes, radiator hoses, center bolts for the springs trany oil, diff oil, brake fluid, and on and on and on.
Cornbinder story #1: Cruising down in Baja we blew a radiator hose. Stopped by the dirt track (not quite a road) we were following, got out a spare hose and the old hose clamp was unusable and I didn't have the right size in stock (bummer). I was standing by a barbed wire fence thinking how it was two strands twisted together and a foot of just one strand wouldn't be to disruptive and doubled or tripled would make a hose clamp. I was standing there trying to look nonchalant because I could here a nother truck coming. Just my luck on a one vehicle every few hours type road one wouldl show up to witness my "borrowing" some wire. I was waiting for it to pass while I was inspecting the trees for bird life and disease. It stopped right next to us. I turned slowly to see another gringo driving the same model cornbinder but he had a service body. He says, "Trouble?" and I say, "blown radiator hose." He gets out, goes to a side cabinet and asks which hose to which I reply I got the hose just need a clamp, its an upper. He reaches in a bin of clamps and pulls out the right one and tosses it to me. Of course as usual he will accept no payment other than my promise to pass on the favor when I get the chance (same rules I go by).
Cornbinder story #2: Only carb trouble I ever had was no fuel in it. We limped a mile or two to a station WAY OUT IN THE DESERT by virtue of my buddy pouring fuel out of a coleman lantern directly into the carb as we were afraid we wouldln't get such a small quantity to feed from the tank. Luckily he understood about fuel/air ratio.
Cornbinder story #3: Once while in Baha I got wheel hop climbing a rough unpaved mountain road and blew the rear end out. Had to back down the narrow winding road and try to back up the hill in 4 wheel drive (due to weight xfer on incline you can't pull up a steep grade with front wheel drive). We made it but later broke a main leaf in the front left leaf spring. Well, with front wheel drive only the main leaf is what ultimately transfers thrust from the axle to the frame to make you go down the road. Without an intact main leaf the axle tries to go off down the road on its own. We splinted the spring with branches, wrapped it with clothesline rope, attached a pair of Vise Grips to it set so tight that it took two of us, each using two hands, to close the pliers. We made it back to the states the next day andmany miles later with out repair still holding. For Baja buffs the hill's name translated from Spanish means the little orphan because a faimily went off the road and plunged to the bottom of the gorge killing the parents and leaving a baby alive. While negotiating this hill in our crippled condition we could look down the steep fall (no guard rails or shoulders) and see the remains of the old pickup.
I'll give everyone a break. The IH saga could go on and on.
Stand by to be envious: I had an 8 1/2x11 workshop manual as thick as the Los Angeles yellow pages that covered every STOCK nut bolt and screw in the entire vehicle and all of the factory options like the PTO winch (Ramsey). It covered all the carb options, rebuild instructions, test procedures, etc. Very handy publication.
Joe, best of luck to you with your Cornbinder. Hope you have lots of fun with the "old soldier."
Patrick
19200 (A50324)
19200 (A50324)
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
2008 Chevrolet Trailblazer SUV (A51694)
2008 Chevrolet...
Life proof SPC Luxury (A53117)
Life proof SPC...
2025 SDLANCH SDLD25 UNUSED Crawler Dumper (A53117)
2025 SDLANCH...
