International Harvester Tractor model S W 6
   / International Harvester Tractor model S W 6 #1
Hondo Alberta,Canada
M-5,IH-S W 6,D65E Komatsu
I'm starting to wonder about this 'I H ' model S W 6,What I'd like to know is there a shop manual on this model.For I believe it is made in 1953 .And also there is no way of checking the motor oil,like no dip stick,also where to add motor oil.:laughing:For it would a great help for any imfo on said tractor.:thumbsup:Thanks ahead of time for any imfo.cause I'm sure :confused:
Please and thanks
   / International Harvester Tractor model S W 6 #2
Not sure about your question on the manuals.
There are two petcocks in the oilpan, RH side, I think. Open the lower one, if no oil runs out, add oil until it runs out the top petcock. Oilfill cap is on the RH side of the engine, a flat threaded cap about 2" in diameter with thumbgrips (wings). Just ahead of the distributer. Use straight weight 30W unless operating in severe cold.
Edit:
Just noticed this was my 3000th post here.
Thank you very much,wasn't sure so I didn't run tractor longer than needed.:thumbsup:
   / International Harvester Tractor model S W 6 #4
IH S W 6 is more correctly an IH "McCormick Super W-6" tractor.
Built 1952 to 1954, essentially the same engine and basic transmission is the IH "Farmall Super M" tractor.
Binder Books sell a reprint of the Operator's manual for tractors with chassis serial number 3952 and above.
Binder Books part # 1004277
Hope that helps!
   / International Harvester Tractor model S W 6 #5
Check out Jensales for manuals.
12 in Small Excavator Bucket (A52377)
12 in Small...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2007 FELLA SM350 3 PT DISC MOWER (A53473)
2007 FELLA SM350 3...
