international harvester 585 oils
   / international harvester 585 oils #1
dimitris stef
greek
I have a INTERNATIONAL harvester 585 {1985} . what viscosity oil can I use in engines. what is the best ; The vine is Mediterranean. 20w-50. 15w-40. 10w-40.? what proteins the manufacturer. The thin oil will burn the machine; because of old technology.THANKS
   / international harvester 585 oils #2
Welcome to TBN.
Do not know about protiens the manufacturer, or thin oil burning the machine.....
I do know in older more used engines, be diesel or gas, a heavier oil may help an older engine not burn as much oil.
In warmer climates such as the mediterranean, a person could use a 20w-50 engine oil. Only thing is I do not know of an 20w-50 oil that is considered a "diesel" engine oil, with the right additives for soot control, a high tbn and other additives a diesel engine oil should have.
15w-40 is a good all-around oil. Its not overly heavy for gas engines but has the additives for a diesel.
I would use a quality 15w-40 engine oil.
   / international harvester 585 oils #3
Welcome to TBN.
i agree 15-40 .. if you run 20-50 in the cold you will take the motor out of it ..seen it happen meany times .. here in the real cold we run 10-30 DMO better start up and easier on the motor
is diesel.If I understand correctly is best 15w 40. and the cold start, and the Mediterranean climate.what specifications to look ,API-ACEA. Thanks for the help
   / international harvester 585 oils #5
Look for a oil that has a TBN of at least 10-11 and sulfated ash over 1, Shell Rimula oil would be a close match the factory oil offered from Case-Ih for that engine.
TBN of at least 10-11 and sulfated ash over 1. not understand. Joined specifications are the SHELL RIMULA R3X 20W-50. SHELL RIMULA R3X 15W-40. the second best;
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A52705)
2018 CATERPILLAR...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
