International harvester 129 help
   / International harvester 129 help #1
Smitrock5
Zanesville Ohio
Cub Cadet 129
Y harvester's mowing deck won't stop running when I shut it off.. I know there is an adjustment on the right side of the mower but no matter how tight that is pulled, it won't make the belt stop spinning...anyone had this problem before?
Sent from my iPhone using TractorByNet
   / International harvester 129 help #2
it has a mechanical clutch on the front of the engine, is the wear pad on the lever/clutch intact? it should be a button about the diameter of a nickel. if that is not it, is the lever still straight?
I'll take a picture of it when I get home scrappy...everything looks straight though...leaving PA now and I'll be home in 3 hrs...thanks
Just now got around to getting those pictures...do these look normal to you? Thanks for the help man!
   / International harvester 129 help #5
First off what I can see in the pic is the upper "finger" on the clutch is out of position. and there is a"button" that those fingers are supposed to hold in that is gone
Do u mean 14 and 15?
I tried taking some better pics after removing the hood and grill...still look the same to you? And if so do you know how to fix er?
I see where that one part is twisted
   / International harvester 129 help #10
the triangular piece is also messed up, a piece is broken off on the RH side in your last picture.
based on what I see, parts 13-15 are either worn or broken.
I can't tell any more without disassembly.
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
KOMATSU D39PX-24 CRAWLER DOZER (A52707)
KOMATSU D39PX-24...
(2) CAM2 HI TEMP LITHIUM COMPLEX GREASE DRUMS (A54757)
(2) CAM2 HI TEMP...
2016 Chevrolet Cruze Limited Sedan (A53424)
2016 Chevrolet...
2015 KENWORTH T680 SLEEPER TRUCK (A56138)
2015 KENWORTH T680...
