International Cub won't start
   / International Cub won't start #1
OrtisEvans
Laytonsville, MD
Ford NAA, Farnall Cub, Kubota B2100
--------------------------------------------------------------------------I posted this in the Farmall Forum, and got no replies. I hope it ok to post here as well.------
I last ran it last fall and it worked fine. I tried to start it in January and no-go. The carb was flooding so I cleaned it an put in a new needle and seat. I checked the spark, which was weak, so I put in points, rotor, condenser, and cap. Still no go even with ether. I thought that I may have put in the distributor out of phase, so I checked it and that is fine. I checked compression and that is good. I thought maybe stink bugs had gotten in the exhaust and clogged it so I disconnected the pipe at the manifold. No help. Today, I pulled the plugs, laid them on the head with the wires connected and cranked to check spark. All are good. I checked timing again by putting a thumb on the #1 spark plug port, and yes, the spark occurred about when my thumb was pushed off. (I assume that the #1 cylinder is at the engine front - nearest the radiator, right?).
I am out of ideas. Suggestions?
Thanks
Ortis
   / International Cub won't start #2
seems you got at least 3 replies including mine?
soundguy
Mitsubishi Mini Truck, 3cyl Gas Engine, 2WD (A52384)
Mitsubishi Mini...
2025 Mower King SSRC (A50123)
2025 Mower King...
44in Tooth Excavator Bucket (A51691)
44in Tooth...
2015 Nissan Sentra Sedan (A53117)
2015 Nissan Sentra...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
