Rotary Cutter International brush cutters
/ International brush cutters #1
SPIKER
Elite Member
Ohio, Jeromesville, Ashland County
Jinma 284
hey all, jsut getting ready to get one a 5' maybe a 6 if the tractor will pull it... I've got a 28 HP JINMA tractor 2 stg clutch live pto, it is one heck of a work horse, had FEL on it all time too. been told that they will pull a 6 footer in most conditiones, not sure.? whats you thoughts on the international brnad and the size.?
Mark M /forums/images/graemlins/ooo.gif
/ International brush cutters #2
With your available PTO hp... I'd stick with the 5' unit for optimum performance, both from the cutter and your Jinma...
I like those International units, in fact they have a stronger A-frame assembly and much heftier blade pan holder than KingKutter... the price leader... /forums/images/graemlins/smile.gif
I haven't been able to set one side by side, but I ahve touched both, and yes they did have more structural supports and thicker metal. I was/am leaning twards the 5' not only for the better brush clearing ability but also the smaller foot print for mowing paths in the woods. I think i'm sold on the 5' just want to make sure that no one can point out anything major that I should look for before I buy.
Mark /forums/images/graemlins/smile.gif
/ International brush cutters #4
I really like my International (7ft). I've cut about 35 acres with it so far in the last couple or so weeks. Really smooth/well balanced. Good bang for the buck. BobG in VA
/ International brush cutters #5
I have an International 5' that I pull with my Kubota L3130HST. She is only rated at 24 PTO HP and I have no problem with engine power, even in hood tall grass. The International I bought only set me back 475 and that was with a slip disc clutch. My Kubota dealer handled them and gave me a good deal when I got my tractor. The cutter does a great job on weeds and grass and does not flinch when I back it into the thick brush. For the price I have not seen anything as heavy and built for abuse. Both my neigbors have them and the one really uses it to clear heavy brush and it now has seen 7 years of heavy use with no problems. The only complaint I have is the paint and cosmetics of the cutter are not good but after all it is a piece of machinery built to do a job not look pretty. Thought I would attach a pic of my set up. Happy mowing! /forums/images/graemlins/laugh.gif
/ International brush cutters #6
Tractor and cutter look good, but man what a view. Very nice! /forums/images/graemlins/cool.gif
/ International brush cutters #8
does anyone know what a 5 foot one weighs all i know is on an 8n if you raise the back tire on the brushmower off the ground you can turn the wheels and go strait
/ International brush cutters #9
I had a 2500 pound JM254, no problem lifting the five foot IMC500. Given that the 8N is over 2700 pounds, I don't see where you'd have a problem.
//greg//
/ International brush cutters #10
I would stay with a 5 foot.
Your tractor would probably handle the weight but HP might be a test in thick grass(the worst offender).
A 5 foot model weighs about 540lb.A 6 foot is about 100-150 more.
/ International brush cutters #11
it will not raise the tires off the ground but you can turn the wheels in third gear so i stear with the brakes
/ International brush cutters #12
Agreed 100%. I think the Int'l is a slight notch above the KK units. That's just my thinking from what I have seen personally with the two units.
For those very observant TBN members, yes, the pivoting bracket on the center link is backwards. That pic was taken right after I bought the unit (used), couldn't quite figure out why I could only raise it a foot or so above the ground!! :laughing: After taking a long hard look at it, I did eventually figure out why lol!
