international 595 deisel
   / international 595 deisel #1
lapkat66
international -case 595 deisel
my 595 deisel runs fine for 15 minutes ,then goes to an idle ,thats it no power up ,next day does the same thing ,new injection pump all new filters ,please help
   / international 595 deisel #2
What type of pump on her?
Check the excess flow return line from the pump to the tank.
If it is plugged that can happen, depending on the pump it could be the first fitting leaving the pump.
   / international 595 deisel #3
Fuel flow could be clogged in the tank or between tank and filter. Disconnect a line as close to the tank as possible and check for good flow. If flow is good check on from there through the filter to see if there's a stoppage anywhere in the line. Sometimes algae starts growing in the tank or lines, especially if biodiesel has been used.
2014 Ford F-550 4x4 Ext. Cab Auto Crane 6406H 6,400LB 3 Ton Crane Service Truck (A50323)
2014 Ford F-550...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
44504 (A51692)
44504 (A51692)
P.T 14' Disc Harrow (A50120)
P.T 14' Disc...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
