International 444 hydraulics quit working
   / International 444 hydraulics quit working #11
The only thing my 444 had that yours does not was power steering and two remotes. It is possible that your tractor does not have a hydraulic filter I guess. The 444 filter is not the normal looking filter and involves a few extra steps to change it that most never encounter. The filter holder actually just looks like oversize part of the hydraulic tubing
Glad you were able to find and clean the suction screen. That may have been your problem. I will see if I can find a good diagram of the filter on some 444s so you can check for it.
With fresh fluid and a clean screen everything is currently working great. Thanks for the help!
   / International 444 hydraulics quit working #14
The IH 444 I owned had a hydraulic filter from the factory. It took me awhile to find it even using the owners manual.
   / International 444 hydraulics quit working #15
I was reading this because my 444 hydraulics just quit. working as well. They have been working slowly for awhile. The fluid and filter was replaced once many years ago. The fluid level looks fine. I have power steering which also quit working . Another question, I have several gallons of Five Point 4000 hydraulic fluid which I am pretty sure is for my 444, however the sticker is faded and hard to read. Is it comparable to HyTran?
   / International 444 hydraulics quit working #16
Clean hydraulic filter and replace oil again ! The IH 444 uses hydraulicfluid in the 3pionthidge That wil do .
   / International 444 hydraulics quit working #17
Is the only fluid add location the one on top behind the seat. I dont remember nor can I find any other loca
tions.
   / International 444 hydraulics quit working #18
tions.
   / International 444 hydraulics quit working #20
AWW,
Did you check the suction screen located by your right foot?
2013 FORD F-350 XL SUPER DUTY- FLAT BED (A58214)
2013 FORD F-350 XL...
2015 Ford Focus Sedan (A56859)
2015 Ford Focus...
1997 HUBBLER BROS. LOGGING TRAILER (A58214)
1997 HUBBLER BROS...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
VICOR HAY CUTTER (A58214)
VICOR HAY CUTTER...
2008 Ford F-250 Lariat 4X4 - 303,424 miles - 6.4L Powerstroke -Automatic (A56435)
2008 Ford F-250...
