International 404
   / International 404 #1
PMA
South Carolina
John Deere 5325, CI Farmall 85U, Mccormick International 404
Just got an old International 404. Need to know how many quarts of oil it holds for an oil change. Thanks
   / International 404 #2
I am having a bad CRS moment. I am pretty sure it takes 5 quarts. I would check it after 4 quarts! I know when I drain it, I get just about a gallon out... I am sorry, but I have not changed oil in that tractor for about a year.... And I need to soon...
   / International 404 #3
I just got a 504 last fall. I've breezed through the books, but don't recall either. I would bet on 5, but like was said above, check it at 4.
   / International 404 #4
404 takes 5 quarts. It was the last iteration of the 113/123 cu. in Farmall engine. They are bullet proof if you take minimal care of them. Good luck with it! BobG in VA
   / International 404
Thanks, I am going to get oil today.
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A53473)
Ditch Witch 6510A...
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
2013 PETERBILT 388 (A53843)
2013 PETERBILT 388...
