International 384 gear cover removal
/ International 384 gear cover removal #1
daedong
Veteran Member
South Australia
The gears are locked and i need to remove the top cover of the box. Has anyone ever done this and could they tell me what to do. Or maybe someone has a manual and could look it up for me.
Thank you in advance.
/ International 384 gear cover removal #2
PM GeneP. He's got a 385 that should be same procedure. I have the book at home, but I'm in Nigeria now. I'll be home in a few days if you get no results.
/ International 384 gear cover removal #3
I sent you a pm, I think you only need to remove the shift lever to realign the shift rails. If you do have to pull the top, get back to me. The hydraulic section has to be raised to get the trans top off, per the I&T manual.
The 384 is a completely different transmission from the 385, but I have a 354 with the same transmission as the 384.
/ International 384 gear cover removal #4
I too am totally unfamiliar with that series of tractors, but on my older IH's all one needs to do is pull the shifter, be able to rock the tractor so it's not binding, and use a big screwdriver to move the rails.
--->Paul
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2014 BOBCAT E32 EXCAVATOR (A60429)
2014 BOBCAT E32...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2012 JACK COUNTY TANK 130 BBL STEEL (A58214)
2012 JACK COUNTY...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
