International 234
   / International 234 #12
Had starting problem with 234 Hydro. Started troubleshooting the problem, once I got it started I could not shut the tractor off. I had to disconnect the fuel supply to shut the tractor off. Has anyone had this problem before? Any help would be appreciated. Thanks!
If the tractor won't shut off again. Just pull the shut off lever on the injector pump. There is a solenoid the pushes this lever that normally shuts off the tractor.
I have encountered this problem a few times. Like you, it was after a starting issue. I replaced the ground cable and carefully cleaned the frame mounting area. The starting and shut off issues went away.
Chuck
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
2025 Unused SDLGC80 60v Electric Golf Cart (A55974)
2025 Unused...
2013 CATERPILLAR D5K2 LGP CRAWLER DOZER (A52709)
2013 CATERPILLAR...
LINDE H70 FORKLIFT (A58216)
LINDE H70 FORKLIFT...
2022 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A55973)
2022...
