International 234 parts
   / International 234 parts #1
GonHuntin
NE, OK
Int 234
I need an ignition switch and a fuel shut-off solenoid for my little 234......any leads would be appreciated!
Thanks, Mark
   / International 234 parts #3
My son has the same tractor and needed the same parts. Will find out where he found them and post that info tomorrow for ya.
   / International 234 parts #5
Case ih dealer will be able to order the ignition for sure. I have bought two (one due to attempted theft and one due to corrosion). They just ordered it took a couple days. They all had the same key so don't throw your present one away yet.
   / International 234 parts #6
Parts were ordered thru Jansen Case IH in Reese Michigan. Will try to get the part numbers for you from my son.
   / International 234 parts #7
Get ready, the dealer isn't cheap!
Ignition switch, part # 1271716C1 - $125.81
Relay, part # 1273053C1 - $119.83
I had searched high and low on the web and hadn't found anything suitable as direct replacements.
Maybe I'll keep starting it with a screwdriver and shut it down manually!!:D
HAMM HD+120I DOUBLE DRUM ROLLER (A51246)
HAMM HD+120I...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
PEMBERTON LR129-1123 RAKE ATTACHMENT (A53426)
PEMBERTON...
Hyster H225E (A47384)
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2025 INDUSTRIAS AMERICA FT510 5' X 10' HYD DUMP TL (A51247)
2025 INDUSTRIAS...
