International 234 Glow Plug Question
/ International 234 Glow Plug Question #1
warment
Cub Cadet RZT54
My father has an International 234 tractor with "K3B 30318" on the engine valve cover.
That being said, I am trying to determine what glow plugs this engine uses. The Mitsu part doc that I have state that the K3B engine is used for one of the following models:
K3B 61A For Industrial Use (STD Model)
K3B 61ES For mini power SHOVEL
K3B 61PA For ANI-perkins
K3B 61SA For sailing boat
K3B 61SG For generator set
Later in the doc, it contains the following 2 parts listed for glow plugs:
MM401621 PLUG, glow (12V NGK Y-110) Except 61ES, WH
MM409510 PLUG, glow (12V NGK Y-114) For 61ES, WH
So then, which part number is used? I assume that since the tractor is not a "mini power shovel" that "MM401621 PLUG, glow (12V NGK Y-110) Except 61ES, WH" is what I need???
/ International 234 Glow Plug Question #2
The K3B uses the same glow plug as my 244s K3D. The International part # is 1273118C1. Of course Case/IH no longer has that part available. However a search for that part # gets you here: Glow Plug | Allis Chalmers 5020,5030,6140 | Case 410,420,420CT | Case IH D25,D29,D33,D35,D40,D45,DX18E,DX21,DX24E,DX25,DX29 | 72097517 | 1273118C1 | 87542790 | 87542790 | 2401-8201-00 | 1273118C1 | 5698-251-1978-0 | 15231-65512 | 3280558M1 | SBA18536. Looks like All States AG Parts has them for $14.40. I would suggest you get an account on caseih.com. It allows you to look up parts for your 234.
Bill
Sorry...I never got around to thanking you for the response...still havent worked on my dads 234 yet, but plan to test the glow plugs soon.
I finally got around to removing and checking the glow plugs. All of them heated up properly when I tested them. Those things sure were in there tight. I assume they have been in there since day one. I put a little anti-seize on the threads when I reinstalled.
