Internal reinforcement in DIY backhoe boom?
   / Internal reinforcement in DIY backhoe boom? #1
NearBeer
Thanks for your time. I have access to some plate steel and have been sketching some ideas out for a stand alone mini-backhoe. Does anyone have any plans or pics of how they reinforced internally the boom? Seen lots of pics of a completed boom but none that shows where and what type of reinforcing pattern they used in fabricating the boom. Any help/advice is apprciated.
In search of my next cold one,
NearBeer
   / Internal reinforcement in DIY backhoe boom? #2
I am not sure what you mean by internal bracing. On my boom, each one of the rotating pieces had a DOM 1 in ID X 4 in tubing welded for the 1 in pins. On the bent section of the boom, 1/4 in steel plate was welded across the joint for reinforcement. It also depends on the thickness of the wall on the box tubing. For light duty, I believe they use 3/16. and 1/4 for med duty, and 3/8 for heavy duty in the DIY booms. If you have doubts about the strength of the tubing, you can add 1/2 in strap down all sides. I haven't done that yet, but might in the future. In my opinion, the box tubing should be 1/4 or better, and all end pieces and joints beefed up with 3/8 plate, with 1/4 in wall DOM tubing on all rotating joints, with grease fittings.
Forgive my lack of clarity in describing what I am trying to ask. If you were to take 4 equal width pcs of sheet steel and were to butt weld them to make a rectangular boom, would you add some type of bracing internally (attached to the inner walls/faces) prior to welding the final piece to complete the boom?
Still searching,
NearBeer
   / Internal reinforcement in DIY backhoe boom? #4
No, the booms are hollow. Often a plate is welded over the butt-weld to reinforce the joint.
Maybe you should search for some plans instead of another beer:D
   / Internal reinforcement in DIY backhoe boom? #5
Butt weld a sheet metal boom , and lift WHAT????????
I haven't found the beer yet...wife is hiding it from me.
FWIW...not sure of actual fab procedures...my comment about butt welding was to better describe my question. Thank for the input:D
   / Internal reinforcement in DIY backhoe boom? #7
You are talking about making square tubing?
And making seam welds?
If the steel is wide enough have it bent into a square channel.
Then weld the 4th side onto it.
Or have it bent into angle iron and weld two pieces together.
As long as the metal is thick enough I don't see why it wouldn't work.
Pooh Bear
   / Internal reinforcement in DIY backhoe boom? #8
I think he is refuring to fabricated booms etc. Like NH curved boom backhoes.
The booms are welded together from 4 pieces of pre cut steel plate ( not sheet metal! ).:)
   / Internal reinforcement in DIY backhoe boom? #9
you would have to stich weld the whole cuz of warpege and that would take awhile
   / Internal reinforcement in DIY backhoe boom? #10
NearBeer-- from an engineering standpoint, you want to have as much mass as possible away from the axis of bending-- i.e., a hollow sructure. Unless you go for an intricate 3-dimensional internal triangle web construction (!!), you want to leave the inside empty.
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
2025 AGT LRT23 (A50123)
2025 AGT LRT23...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2025 K2223 UNUSED Double Garage Metal Shed (A53117)
2025 K2223 UNUSED...
2008 FORD F550 XL SUPER DUTY DUMP TRUCK (A51406)
2008 FORD F550 XL...
