Internal over-running clutch
   / Internal over-running clutch #1
jonrjen
Bronze Member
Can someone explain how this set up works? Is this like a live PTO, ground driven PTO, a two stage PTO? Can it be used for the purpose of use of a Post Hole Digger?
Thanks in advance.
   / Internal over-running clutch #2
Re: Internal over-running clutch
Think of it as a one way valve. Power can get from the engine to the implement, but power can't get from the implement to the tractor. If the say a rotary cutter is still running and you shut off the tractor, it will allow the PTO shaft to keep turning without pushing the tractor. It has no use for post hole digger.
   / Internal over-running clutch #3
</font><font color="blue" class="small">( Think of it as a one way valve. Power can get from the engine to the implement, but power can't get from the implement to the tractor. If the say a rotary cutter is still running and you shut off the tractor, it will allow the PTO shaft to keep turning without pushing the tractor. It has no use for post hole digger. )</font>
A better example may be a ratchet and socket. The socket is the pto shaft and the ratchet the PTO. The PTO applies pressure in one direction, like the ratchet, and the overrunning clutch allows the PTO shaft, like a socket, to turn freely in the same direction.
So is Jerry saying this is not a good set up for use with a Post hole digger?
   / Internal over-running clutch #5
</font><font color="blue" class="small">( So is Jerry saying this is not a good set up for use with a Post hole digger? )</font>
It's as good as any other. The internal clutch has no bearing on posthole digger use.
   / Internal over-running clutch #6
<font color="blue"> The internal clutch has no bearing on posthole digger use. </font>
That's right.
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
2017 Ford F-250 Knapheide Enclosed Service Truck (A50323)
2017 Ford F-250...
