Intermittent starting problem
   / Intermittent starting problem #1
paradox998
JD 4500
I have a JD 4500 with a starting issue. When cold, the tractor will turn over but not start. Several years ago I got frustrated with the seat pressure switch and took it out. I put the red and white and red wires from the switch together. All was well. Lately the starting problem began. When I check the wires they are tightly together. When I put the wire nut back on and then the tractor will start. What should I look for next? Has me baffled.
   / Intermittent starting problem #2
Leave the wire nut on then.
That's the puzzle. I try to start the tractor and no luck. I take the wire nut off and put it back on and it does start. The wires are twisted tightly together. Maybe there is a fault further down the wire and just moving them works. Once the tractor is warm it starts fine.
   / Intermittent starting problem #4
The wires may be a bit oxidized. Taking the wire nut off and replacing it may be contacting a new area on the wires permitting better conductivity. You could try replacing the wire nut with one of the grease filled underground variety.
2007 Ford F-150 Ext. Cab Pickup Truck (A48081)
2007 Ford F-150...
UNUSED CFG EXCAVATOR FLAIL MOWER (A50460)
UNUSED CFG...
2019 CATERPILLAR 313FL EXCAVATOR (A50458)
2019 CATERPILLAR...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2005 Northwood Artic Fox 335V T/A 34ft. 5th Wheel Travel Trailer (A48082)
2005 Northwood...
2008 Fisher 180 Pontoon Boat and Trailer (A48837)
2008 Fisher 180...
