Intermittent stalling
   / Intermittent stalling
Talked to dealer, they said they had just finished "fixing" a machine that had some of the same symptoms I'm getting. They said to check the fuel line coming from the fuel tank, that is right below the brake pedals. It may seem fine when it's not working, or off, but under load the lines apparently tightens and may cause a crimp or bend, which results in engine starving itself.
I checked it, seemed OK...gave it a bit more slack and will see what it does. Personally I don't think it will change anything, plus I checked all fuses, and they were all good.
We have 1 foot of snow coming, so hopefully (fingers crossed...) she runs good, but I wouldn't be surprised if it stalls. I'm hoping there will be enough of a snow break next week to take it to the shop and have them look it through.
IMPORTANT UPDATE:
tractor is back in shop as we speak.
Items checked and still no dice:
Engine belt tightened (snow can cause slippage if already loose, then give alternator no power, and then tell the computer there is no engine on, therefor all shuts off)
Fuel pump seems ok, new one was tested and has same results.
Next is fuel filter. However when it was checked there was water accumulated, but was removed...
All these were checked, we were loading the machine all was good, and it stalled right on the trailer, so back into the shop it went.
Now fuel, to me seems to be the issue. We have a 1400 liter tank of diesel, and then a 400 liter tank of colored for the 3520s at home. It went empty this winter, so maybe upon fill-up there was condensation. But, what troubles me is wouldn't our other 3520 be doing the same if it's feeding off the same diesel:confused:
Anyways, hope to get some good news later on today. It's really no use to me for work if it can't run properly...
Just hoping the gremlin is found, wherever it may be!
   / Intermittent stalling #13
If the fuel is suspect now. I think I would drain fuel from the tractor tank and refill from another source with fresh fuel. Treat this fuel with a diesel anti gel and also add 10 to 15% Kerosene, just to eliminate the slight chance of it being a fuel problem. That should tell you if it is the fuel. If the problem happens again your going to have to look elsewhere. If its not the fuel it almost sounds like an electrical problem somewhere. Good luck and keep us posted.
Sincerely, Dirt
Problem solved!:D
So, problem has finally been located. We are some upset with our diesel delivery company.
The dealer found 1 inch of really dirty sludge at the bottom of the tank, which of course would clog the fuel line. The screen on the lines would get so plugged that fuel would not run to the engine anymore.
Since that's out of the way, no more stalling:)
Thanks to everyone for your help, specially Dirt.
Looking forward to working with a smooth running machine again.
Merry Christmas + Happy Holidays!
   / Intermittent stalling #15
I wouldn't be so quick to blame the fuel supplier. The problem is probably in your tanks. You need to take a couple of steps to prevent further problems. Check the pick up tubes on your tank pumps and make sure they are a couple of inches off the bottom of the tank so they are not sucking up water and crud off the bottom of the tank. Second, install some fuel filters inline on your tank so the fuel you are dispensing is filtered. GOLDENROD is a good name brand filter. I use one standard filter and one water block filter in series.So my fuel gets doubled filtered at the tank and then again in the machine. NO, fuel problems in over 13 years out of the same tank. You can also get some water indicator grease to ''stick'' your tanks to detemine how much water you might have in your tanks. What I have is Yellow grease which turns Red when it comes in contact with water. Smear the grease on a piece of wood from the bottom about 6 inches up. Then stick into your tank clear to the bottom. If it indicates water, I'd try and pump the water with another pump off the bottom until it changes to good fuel.
Clean fuel and clean air are the two main things that will keep your machines running without problems.
Sincerely, Dirt
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2015 Case TR340 Compact Track Loader Skid Steer (A55787)
2015 Case TR340...
2014 KENWORTH T680 SINGLE SLEEPER ROAD TRACTOR (A54756)
2014 KENWORTH T680...
UNUSED PE Industrial Stretch Wrap Rolls (A53117)
UNUSED PE...
Hutchinson 10x71 Transport Auger (A50775)
Hutchinson 10x71...
