Intermittent blue/whiteish exhaust from MF1754
   / Intermittent blue/whiteish exhaust from MF1754 #1
madtowneast
Massey Ferguson 4707
Hi All,
I have been happy with my 2016 MF1754 so far. I had a 1000 hr service done roughly 60 hours ago (6 months ago). Everything was fine, but now when I drive through a bumpy part of my property I see some blue/white exhaust coming out of the exhaust intermittently. Like it starts goes away for a bit comes back. It only happens after running the tractor for a bit. It starts up no problem. The temperatures have dropped since the last time I used the tractor, but I doubt it is just water vapor. I can’t smell anything off though besides the smell of maybe burning diesel. Anybody have a good idea how to diagnose this without going to the dealer?
Thanks!
   / Intermittent blue/whiteish exhaust from MF1754 #2
My first thought just from your description: Is there water in the fuel? It's not hard to change a fuel filter. That would eliminate one variable.
Just keep in mind I'm only guessing at this.
did check the fuel filter… is there water separator somewhere or just the filter?
   / Intermittent blue/whiteish exhaust from MF1754 #4
I don't know if your filter looks like this one in the YouTube but if it does then you should be able to see a definite line in the filter between the water and the diesel if that is in fact your problem. There is nothing wrong with changing the filter as a precaution.
Chances are there is no other separator as this one would give a definite indication if water is an issue. But again I don't know as I'm not familiar with these tractors.
   / Intermittent blue/whiteish exhaust from MF1754 #5
On my 1736 there is a separator with a red ring that will float on top of the water then the fuel filter, both have filters in them and drain valves in the bottom of their housings. There is a metal shroud around them that is not shown in these pictures.
View attachment 837495View attachment 837496
Thank you! I know there is a little window on the metal shroud around the filter. I will need to check if the red ring is visible.
Well I just checked and I don't have that red band at all... I checked the parts book and they don't list it either...
   / Intermittent blue/whiteish exhaust from MF1754 #8
Interesting, searching online for my 1736 and your 1754 I find the following page which shows a picture of the assembly with the red ring, the picture is upside down for how the part is mounted on the tractor:
Yeah I saw that too. But there is no part in the parts diagram. I am guessing it is part of the assembly and you can't buy it separately.
   / Intermittent blue/whiteish exhaust from MF1754 #10
Yes, However I think your dealer may be able to drill down further on their system and find that part.
I changed my filters one time and I had put everything back together and purged the air from the system only to find the red ring when I was picking up my tools so I got to practice putting it back into its housing. I wonder if that happened to yours?
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
72" Hydraulic Broom  (A52384)
72" Hydraulic...
2014 International WorkStar 7400 Truck INOP, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
Aluminum Boat and Trailer (A51573)
Aluminum Boat and...
JOHN DEERE 560M LOT NUMBER 15 (A53084)
JOHN DEERE 560M...
