Interminent Starting Issues
   / Interminent Starting Issues #11
if the starter turns the engine when jumped, the negative cable is good!..
   / Interminent Starting Issues #12
All good ideas, I'll dig further into it later this week when I have the time.
Fallon- I did "jump" the starter to rule out the starter.
Splitting hairs here...but:
That depends where he connected the negative jumper cable.
If connected on the negative battery post, cable is probably good. If on the frame, neg. battery cable and/or connection to frame is still a possibility.
   / Interminent Starting Issues #13
I would assume he only used the positive cable!. that's the usual way to "jump the starter"..
   / Interminent Starting Issues #14
I have a L3700 SU, it's the little brother to your tractor. ..if I were a betting man..I would say it's your neutral switch on the HST pedal. They are notorious for failure. Try rocking the HST pedal while turning the key at the same time....
   / Interminent Starting Issues #15
Correct. Generally you only touch the positive cable to the input stud on the starter. There is no negative connection. Starters were designed to use the engine block (then ground strap & frame) as the ground.
   / Interminent Starting Issues #16
So I was using the tractor yesterday and has the clicking , no start thing going on. Rocked the HST pedal a few times and it fired up. Today I tried to get it off the trailer and the same thing but took about 10 minutes to fire up. A few years ago I condemned the HST safety switch for the same issued and replaced it. Actually bought another switch a few months back but never installed it. So today, I pulled the 1 bolt that holds it in, pushed the plunger that the pedal activates it with my finger and instantly it fires up. So in a nut shell, I just had to drop the threaded lock nut down a bit to push more on the plunger and call it a day. Zero cost. Hopefully this problem is solved for a good long time.
   / Interminent Starting Issues #17
The one by your right foot I did the same thing a couple of years ago........
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A56436)
Gleaner N630 Corn...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2012 International DuraStar 4300 Flatbed Truck (A55973)
2012 International...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
