Interesting Video On Mower Deck Spindles
   / Interesting Video On Mower Deck Spindles #2
Yeah...sealed bearings where a zerk is suppose to grease them. My old Cub Cadet has 1" blade shafts with tapered roller bearings and they will out last me.
   / Interesting Video On Mower Deck Spindles #3
The top bearing still doesn’t get any grease in it. If you pumped the cavity full of grease to actually push grease in the top bearing then you’re going to push the seals out. I think quality sealed bearings are the better way. Maybe an oil filled cavity with a splasher on the shaft to throw oil on the top bearing would be the best solution.
   / Interesting Video On Mower Deck Spindles #4
Yep, so now you can pump the seals out with grease and allow the dirt to get in. Oh, and good luck putting the nut back on those threads you just hit with a hammer. JEEZE!!!:confused:
   / Interesting Video On Mower Deck Spindles #5
A claw hammer no less............
   / Interesting Video On Mower Deck Spindles #6
Hitting the bearing out with a steel punch directly to one side of the bearing is a sure way of putting a small bulge in the bearing limting its life bearings deform when hit with hard objects if you have to hit the bearing to get it out replace it with a new one
They just cut right off with a utility knife. As for tearing them up knocking them out I see this more as a when you replace them option. No dirts going to get in either as you are only cutting one side . That’s the side that goes in the spindle where it’s protected.
   / Interesting Video On Mower Deck Spindles #8
Or you can just pop the seal out with a dental tool. The idler wheels that have no zerk can be greased this way. Pop the seal out, pump grease between the bearing balls with a needle tip, install the seal again.
   / Interesting Video On Mower Deck Spindles #10
LOL, you would be surprised how many would put sealed bearings in again and continue to put grease in zerk...
UNUSED Roof Thermal Insulation (A53117)
UNUSED Roof...
2019 Chevrolet Tahoe SUV (A51694)
2019 Chevrolet...
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
2023 UNVERFERTH 432 LOT NUMBER 32 (A53084)
2023 UNVERFERTH...
2011 Lexus RX SUV (A53117)
2011 Lexus RX SUV...
