Interesting source of goodies
   / Interesting source of goodies #21
No input? Well guess I am the test subject. I ordered one and put it on this weekend. I ordered the:
"VEVOR Shaft, 1-3/8” PTO Drive Shaft, 6 Spline Both Ends PTO Driveline Shaft, Series 4 Tractor PTO Shaft, 49”-71” Brush Hog PTO Shaft, Black PTO Shaft with Slip Clutch for Bush Hog/Finish Mower" Total cost $152.99​
So far so good, got about 2 hours of shredding done. It came pre-lubed, shipped to the house in 4 days via Fed Ex. It has 2 bolts with nylon lock nuts for the implement end and standard spring buton on the tractor end. I did grease the yokes a little just to make sure. I have not tried the slip clutch. The whole set up looks just like the one I removed from my Modern Ag shredder. The only issue I found was when I removed the 2 shafts there were a few metal shavings on the end of the female part.
MOTOR PUMP & HOSE (A52708)
MOTOR PUMP & HOSE...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
11' x 19' All Metal Carport (New/Unused) (A59225)
11' x 19' All...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Poly Bristle Sweep, 78" x 8" (A59076)
Poly Bristle...
Year: 2014 Make: Volkswagen Model: Passat Vehicle Type: Passenger Car Mileage: 135,272 Plate: Body (A56859)
Year: 2014 Make...
