INTERESTING FACTS
/ INTERESTING FACTS #1
lilyperch
Herrick, IL
2016 Kioti NX4510 HST Cab Backhoe
These are the tractors I am pricing right now. All with cabs, FEL and backhoes, hydraulic thumb, grapple, high back hd box blade, high back hd rear scraper, ripper tooth, 4000lb pallet forks, 2 rear remotes, 3rd function and ag tires filled.
Kioti NX 4510 5510 all turbo 111 cubic inch
Mahindra 3540 3550 Non turbo 166 cubic inch
Kubota L4760 Non turbo 148 cubic inch
PTO HP very close except Mahindra 3540 only30 pto hp others are 38-39hp.
List of facts after dissecting specs.
Kioti FEL KL6010 BH KB2485
Mahindra FEL 3550L/3550cl BH 50B/50CB
Kubota FEL LA1055 BH BH92
Kioti pto lift 2760 Mahindra 3090 Kubota 3177
Kitio weight 4068 Mahindra 6189 Kubota 4315
The below specs in same order as models listed
FEL lift capacity 2761lbs 2700lbs 2361lbs
Breakout force 2990 5100 3171
Dump angle 66 deg 40 46
Rollback angle 31deg 20 42
Backhoe specs same
Digging depth 94.4 115 109.8
Bucket force 3748 5710 4548
Dipper force 2205 3188 2698
Stabilizer spread 68.7" 127 92
In my opinion Mahindra much stronger machine by 20% over Kioti and 40% over Kubota. Kioti stronger than Kubota by 30%.
Kubota will be the highest priced model. My main concern is Mahindra 3540 may be underpowered.
They don't make it easy to compare.
What are your thoughts???
Thank you.
New/Unused Wolverine Quick Attach Auger (A65583)
New/Unused...
Case 2090 Tractor (A66285)
Case 2090 Tractor...
New/Unused ATS T460 Mini Skidsteer (A65583)
New/Unused ATS...
Hydraulic Breaker Excavator Attachment (A64553)
Hydraulic Breaker...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
