Interesting double tractor
/ Interesting double tractor #2
That wide stance ought to be nearly impossible to turn over.:D
LOL thats true I ddint think of it that way..
/ Interesting double tractor #4
Uh, why?
/ Interesting double tractor #5
Your right Bird....That would be hard to flip.
/ Interesting double tractor #7
That tractor is neat!
I was just thinking about driving a tractor across the US and pulling a little camper. I wanted to take my wife along too!, that tractor is the answer. But I just know when I want to turn right, she'll want to turn left.
/ Interesting double tractor #8
Looks like someone has lots of free time on their hands. Neat looking whatchmacallit.
/ Interesting double tractor #9
Another example of what happens when the winters are long, shops are heated, and welding rods are cheap! :)
All that said, it was well done and pretty cool. Usually you see those old tractors scabbed together nose to tail to make 4WDs
/ Interesting double tractor #10
By putting 2 8N's together, do you get a 16N or a 88NN?? :rolleyes:
:Doh goodness dont make me do math this early or late in the day LOL:D:D:D
/ Interesting double tractor #12
Not a new concept, just a different way of doing it. At one time before high horsepower units were available it was common place to join two tractors in tandem to get the job done. Most people just were not as creative as the guy with the 8n's
/ Interesting double tractor #13
It would take an acre to turn that thing:D
/ Interesting double tractor #15
So does each engine drive the rear wheel only on it's side? How does the clutch work, wonder it has them linked someway where you are working both at same time and then how do you get both adjusted to mate. How about engine speed and cranking them? Wonder if he put better brakes on his combo than they came with? Is amazing.
/ Interesting double tractor #17
Here would be my guess. If he welded the two inside axles to each other, then he'd have the two differentials working together. That way both engines drive both wheels, and he doesn't have to precisely synchronize the two engine speeds to keep it going straight. I'm betting that the throttles, clutches, etc. are all synchronized to each other. It would be like the throttles on a two cylinder motorcycle engine with dual carbs. The starters and chokes may or may not be synchronized. It may be easier to start each engine separately.
As to the "Why?" question; I see it a lot like going to the moon. The end result in and of itself may not have much benefit to the world. The real value lies in what was learned in the process.
/ Interesting double tractor #18
I would bet my own money the differentials are welded solid and the inside axles are removed. If you joined the inside axles together all that would happen is the wheels would remain stationary and the inside axles would spin at twice the normal speed, just like a regular diff does when one wheel loses traction completely.
/ Interesting double tractor #19
Oh, yeah. That's right. I didn't think that through completely. What if he only welded one differential?
/ Interesting double tractor #20
Hello
I am new to the site. I am a heavy equipment mechanic who was raised in a small farming community. My dad and I have rebuilt several old tractors including a Farmall M. I just bought an Ajax motor and am very intrested in making my own tandem tractor. I was thinking before I do it on a real tractor I will make a tandem lawn mower. Any ideas?
YARD MULE (INOPERABLE) (A63569)
YARD MULE...
SET OF (9) PUMP BOXES (A63569)
SET OF (9) PUMP...
12x20 Metal Carport (A64047)
12x20 Metal...
2019 KENWORTH T880 (A63569)
2019 KENWORTH T880...
KUBOTA BX23SLB-R-1 TRACTOR (A62129)
KUBOTA BX23SLB-R-1...
25FT FLATBED DOVETAIL TRAILER (A63569)
25FT FLATBED...
