Interesting boom pole lift...
/ Interesting boom pole lift... #2
Ya. Interesting idea. Stump don't weigh no 3500lbs though (IMHO).
/ Interesting boom pole lift... #4
I agree no where near 3500 lbs. if it was that boom pole would have crumbled.
I have to agree, was thinking the exact same thing.
Neat little pig pole however.
/ Interesting boom pole lift... #6
Stump may weigh 500 lbs but no way does it have 3000# of dirt in the first one. Not even a 120 HP utility tractor would lift 3500# at the end of a 9 foot boom pole even if the boom had the strength to lift that amount. Typical Craigslist exaggeration.
/ Interesting boom pole lift... #7
Wrong. My 75HP tractor will lift about 3000# at the end of a 108" boompole with the 3ph. ... #75
http://www.tractorbynet.com/forums/buying-pricing-comparisons/145738-conversion-factor-3ph-load-capacity-2.html#post4117957
The lift on the boompole shown is not done by the 3ph, which only holds it. The lift is done using a separate hyd cyl.
,,,My tractor loader will lift 2 tons to full height. A stump as shown, even with dirt, would be no problem, but appearances of ~ 500 are grossly deceptive.
/ Interesting boom pole lift... #8
I'd guess the stump is closer to 1000 pounds. I think $800 is way too high too.
/ Interesting boom pole lift... #9
This boom pole is different enough to post the pictures for future readers, after the craigslist ad is gone:
/ Interesting boom pole lift... #10
I like all kinds of tools and some folks would say I have too many... but I just can't figure a way this device would add any kind of value to me as I already have a heavy duty, square tube boom pole with no hydraulics. Seems like an implement seeking a specialized purpose.
/ Interesting boom pole lift... #11
Wow - that is one HD boom pole to lift 3500lbs at 108" - even bigger than I want but I been looking for a HD boom pole but the best i found is around 2K rated at 80 some inches, where did you find yours? Wouldn't mind seeing photos of it if you have some to get some idea of how it is built (may end up building my own just for a fun project with my son)
/ Interesting boom pole lift... #12
... I said my tractor would lift about 3K. It is based on an extrapolation of info/measurements in the link given. ... It is a strong boompole tho - cat1/cat2 - rectangular top tube. Its probably rated a ton @ at the end. Might do 3000 ok in static or very careful conditions.
/ Interesting boom pole lift... #13
I would make use of that pole tomorrow first thing. Staking chord wood! those bigger pieces need a lift ;-)
/ Interesting boom pole lift... #14
I have a long, rectangular, heavy duty boom pole apparently similar in size to that one. It is raining now and early... so am not going to measure mine. It could be a foot or so shorter tho- but is longer than the typical lighter weight poles I have seen.
So is your comment because of the length of the pole for accessibility or because of the pole's hydraulic lift of the load at that extension is more than your tractor's 3PH can lift?
/ Interesting boom pole lift... #15
sdef
rainy here too ;-(
The hydraulic action of the boom combined with the length of the pole would make for a large range of motion, convenient for handling and stacking 4 foot cord wood.
I can't imagine a cut length of firewood exceeding the 3PH. Or if that's is what one had, it could be cut into stove lengths and then moved.
/ Interesting boom pole lift... #16
Anyone ever drive a tractor over uneven ground with a heavy load suspended like that? Seems like it would be a little squirrelly if it got to swaying.
/ Interesting boom pole lift... #17
I think you need a better extrapolater. Unless you have enormous weight on the front end, it is going to be in the air way before you lift 3500# from 9 feet back. I don't doubt that your hydraulics would hold that amount while using the top link ram to lift the boom, but your tractor wont be heavy enough to stay on the ground with that kind of leverage applied.
I see from you link posted, you argued against the total forum that distance from the tractor made no difference in lift capacity which is absurd.
/ Interesting boom pole lift... #18
Absolutely. ... Boompoles are strong for the lift, true. A heavy swinging load is much more of an issue; both for the pole - and for a small tractor.
/ Interesting boom pole lift... #19
I said 3000#. Tractor has a loader. 3K might be an issue w/o the bucket, but not with - even empty, when you count the tilt tatch and bucket there is over a thousand# lumped more than 6' ahead of the front axle. Not to mention all the loader and tractor weight that is ahead of the rear axle.
,,,,,,,Wrong. ... As you would find if you read the thread. The 3ph approximates a //ogram linkage. The accuracy of this approximation varies.
/ Interesting boom pole lift... #20
Yep and from what I understand, is the reason boom poles fail. My heavy boom pole- similar to the one in question can exceed the balance weight of my tractor with a 2k# load on it and no additional weight up front for counter balance) I imagine and is not the reason I purchased it. I purchased mine to be as safe as possible with any load I may have on it and it starts swinging and not have the pole fail.
Now sometime in the near future I am going to have to hook up the pole and place the hydraulic top link in full retract and measure the height off the ground of the end of the pole. I know it will be substantial- guessing 6' or so extrapolating the angle and height the rake is at in the same position.
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
WEATHERHEAD COLL-O-CRIMP T450-1 HOSE CRIMPER (A64276)
WEATHERHEAD...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
Skid steer Asphalt attachment (A61567)
Skid steer Asphalt...
Caterpillar 572E Tracked Pipe Layer (A64553)
Caterpillar 572E...
