Interesting attachment
/ Interesting attachment #1
Steverino
Central Connecticut
Kioti CK30HST FEL & BH
Here is a link to an attachment advertised for Kioti compact tractors on e-bay. I have my doubts as to the effectiveness of the digging depth and the loader to handle it. Just my 2 cent opinion.
Shortened Long Link
MikePA: Please review your message before posting it. It's simple not to create a long link that widens the entire thread. Just insert a descriptive word or two between the {url=http://whatever}<font color="red">Enter words here</font>{/url} instead of the entire URL. Replace parentheses {} with square brackets in previous example. Alternatively, if you use the Instant Markup language URL link, the first prompt is for the URL. The second prompt is for a description. Do not simply paste in the URL again. Type a short description of the link. Note: Following standard Internet protocols, bolding is for emphasis and should not be confused with all capital letters, which represents shouting. Also, this instruction is done in public so that others may learn as well.
Shortened Long Link
/ Interesting attachment #3
I help a friend that has a nursury and he uses a hydraulic spade like that but only for a 22 inch ball. It's to big for his JD770 and will lift it right up when digging, so he must use it on his much larger JD.
Seeing that this one does a 32 inch ball, I probably wouldn't put it on anything less than a DK35 but a better match would be a DK45. 650lb piece of equipment and a 250-300 root ball would be heavy for a CUT and you need the weight of the tractor to keep it down.
Just my opinion after using one and seeing how they work.
/ Interesting attachment #4
/ Interesting attachment #5
Thats a pretty unusual find Steve.. Wonder how good they work?
/ Interesting attachment #6
/ Interesting attachment #7
I think it's way too much for a CUT as set up. I may be new to tractoring, but I've operated many tree spades from small 24"ers to 60+" and you need something that is heavy and stable (relative to spade size)to properly accomplish your dig. That one appears to put the wieght well in front of the pivots on the loader frame, would probably be better as a rear, 3pt attachment. That would center the wieght tighter to the tractor, plus you'd have greater ability to lift it. Might be fine if your digging little Arborvitea growing in well drained sand. If you dig a good sized hardwood in loamy soil I think you'd overload the set up quick. /forums/images/graemlins/shocked.gif
/ Interesting attachment #8
/ Interesting attachment #9
Looks like it might work with at least a DK35, I think it would be too much for a CK20 in most soils. The size trees the ad refers to shouldn't be too much, but it's the conditions one is digging into that would worry me.
It doesn't take much to lift the front on my CK20 just while doing loader work so I think this would lift it a great deal instead of putting all the power into digging.
On a DK45 it would be awesome.
I wonder if that "universal front loader mount" is the quick attach type that could be used for other implements. That could be a nice addition, but most guys with the larger tractors already have them.
John
John
/ Interesting attachment #10
John
John
/ Interesting attachment #11
The add states the following;
250-300 pound root-ball weight (approximate)
Use for most 2-3” trunk diameter trees
Use for most trees/shrubs up to approximately 8 feet tall
A 3" Oak or Hard Maple is going to be well over 8' tall, probably approaching 15-20'. Now add a damp 32" root ball. Still think it'll fit into the lifting capabilities after adding 650 lbs for the implement? I personally wouldn't put that on my 30, probably would want a 50 hp or larger ag sized tractor. The other consideration would be; are you digging in nursery stock or are you harvesting wild grown? It is much more difficult digging wild trees with competing roots from larger trees, rocks, clay deposits, etc... I think if you tried to harvest a 2-3" hardwood in the wild with that setup on a small tractor you'd just lift the back of the tractor up or hit relief. Remember, you're not just lifting wieght off the ground, you are extracting something buried in it.
That said, it is a cool set up for the correct machine. I wouldn't mind a 24-26" setup for my machine if it centered the wieght a little closer to the pivots, wieghed a smidge less and had QA. It appears that this one pins on, no QA. I have been moving a bunch of small cedars and spruces around my property, a 24"er would be perfect for this.
I don't mean to sound so negative on this, I like the principle just think it's too much for a CK20 or 25/30 for that matter.
/ Interesting attachment #12
/ Interesting attachment #13
As a point of reference, my FIL split his NH TC40 in half using a 36" tree spade (granted after a few years and probably 1000 trees worth of usage)
/ Interesting attachment #14
Brent 320 Grain Cart (A65640)
Brent 320 Grain...
Keota MFG Bale Mover (A65640)
Keota MFG Bale...
Case IH 5100 12ft. Soybean Special (A65640)
Case IH 5100 12ft...
Bulk Lot - (10) 8in x 20ft Fat Lip Pump Hoses (A63689)
Bulk Lot - (10)...
100 gal Portable Fuel Tank (A66408)
100 gal Portable...
Used Landpride GR1525 Stump Grinder
Used Landpride...
