Interchangeable oil filters for 425
   / Interchangeable oil filters for 425 #1
BAGTIC
Thayer, MO
What aftermarket oil filters can be substituted for the Power Trac filter? It is a little tight getting a good grip on the PT filter but if I could find another brand filter with fluted ends it would be possible to use use one of the cup type filter wrenches with a socket wrench.
   / Interchangeable oil filters for 425 #2
A couple of questions...
1. are you talking about the engine filter?
2. or the Hydraulic filter.
I just changed my hydraulic filter. 50 hour service. (425- Late 12/04 model), and I could not get mine to come loose either. I opened the bleeder port just a little, then used both hands,(I have very bad tendonitis) and was finally able to get it to turn loose. I don't know if opening the bleeder port let the filter release because of pressure, or if I just got mad enough to finally get it to move. It took me about 45 minutes of struggling before I finally got it loose.
   / Interchangeable oil filters for 425 #3
My PT had a NAPA filters on it when I bought it used. The NAPA hydraulic filter is a NAPA Gold Fluid Power Filter 1551.
However, it doesn't have the fluted ends on it, as I recall...
   / Interchangeable oil filters for 425 #4
Gentlemen
Relief is at hand spelled rolaids---SORRY--- let's try
K D No 2029 sold at your local NAPA dealer.
Here's three shots if I'm lucky, Incidentallly this is a reversible unit once you get the hang of it, used 'em for years in the auto bus.
Bill
   / Interchangeable oil filters for 425 #5
and again-----
   / Interchangeable oil filters for 425 #6
and another------
   / Interchangeable oil filters for 425 #7
O K Bill cut out those senior moments and let's try for the correct other one.
Here goes-----
   / Interchangeable oil filters for 425 #8
Sorry about the Senior Moment.
Here's another one for bonus.
This is actually the weakest part of the filter, I took the shot for a better view of the installment of the tool. The strogest part is at the sealed end where the captype tools fit.
All th Best. Bill
   / Interchangeable oil filters for 425 #9
When I seen Bill's attachment I wanted to look and see if my oil filter changing wrenches were still there. Looks just like my set.
Oh yes. I can’t remember whose idea it was but don’t forget to use that plastic Wal-Mart bag around oil filter, wrench and all before you screw it out. It really saves a mess that you would normally have to clean up.
   / Interchangeable oil filters for 425 #10
Thanks Craig,
I also initiated the plastic bag idea quoting a 1 gallon Zip Lock bag, I don't do too much Wal-Mart shopping, but I'm guessing their bag is possibly larger, I'll go shopping and find out. Thanks for the reminder.
Bill.
ps Yes that is my KD tool. I gave my original along with most of my tools to my youngest. The present one is the first thing I bought after seeing my PT construction.
UNUSED JCT 72" HD VIBRATORY ROLLER (A51248)
UNUSED JCT 72" HD...
2022 John Deere 8RX 410 Tractor (A53342)
2022 John Deere...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
EZ-Go Golf Cart (A51573)
EZ-Go Golf Cart...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
