Inter-axle ratio
   / Inter-axle ratio #1
ags1517
Does anyone please know what the inter-axle ratio should be for a Kubota L2850. I want to run Goodyear Soft Trac 44-18-20 on the rear, and am trying to work out what the front size should be.
   / Inter-axle ratio #2
Can you figure the difference in percentage of the old rear tires compared to the old front tires? Example, old rear tires are 48'' dia. old front tires are 30' dia. Front tires are 62.5 % as big as rear tires. New rear tires 50''. New front tires would be 31.25" If you want more or less lead or lag in the front tires, add or subtract the needed percentage. On stock car tires we would use the circumference of the tire because that is a more accurate measurement.
2018 RoGator RG1100C Sprayer (A53342)
2018 RoGator...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2023 JOHN DEERE 8R370 LOT IDENTIFIER 205 (A53084)
2023 JOHN DEERE...
2016 JOHN DEERE R4038 LOT IDENTIFIER 181 (A53084)
2016 JOHN DEERE...
JD 1814E LOT IDENTIFIER 265 (A53084)
JD 1814E LOT...
