unadilla said:My intel panel lights blow fuses. I have had it to the local dealer and they can't find the fault. I changed the 7.5 amp to a 15 amp. It takes longer to blow but it still blows.
unadilla said:Thanks. It takes about 30 min to blow. The 15 amp fuse was the dealer's idea. I will do the ohm check tomorrow.
Bill
unadilla said:Today I discovered that the fuse that blows is marked on the cover as the Alternator. Isn't that odd?
Bill
unadilla said:Andy, I think you got it. I unplugged the alternator, replaced the fuse and the panel lights came on. Could it be a diode in the alternator?
Bill
Another possibility is an intermittent failure (probably a short) Does the failure always take about 30 minutes or is it sometimes much longer or shorter. If it varies then it is most likely an intermittent failure. The failure may only occur randomly or under certain vibration conditions or when the system warms up. I would put a headlamp across (in parallel with) a blown fuse. The lamp will get brighter when the failure occurs. You can them easily monitor the situation. You can wiggle wires, tap things, and let the engine warm up. For example the alternator could be failing when it gets hot. I have used this several times to find problems. It is also very safe. It also helps to have a second person watch the light while you wiggle things.unadilla said:Andy, If it fried all or part of the alternator what could have caused it? I will take the alternator to the shop tomorrow.
Bill
AndyMA said:Bob gives good advice. I still think that the alternator shop can determine what (if anything) is wrong with the alternator. Assuming the alternator has an integrated regulator that could also be th esource of the problem. Make sure that you tell them that it usually takes itself about 30 minutes to occur.
Andy
BobRip said:My concern would be the shop would test it cold and it only will show a problem when hot. I believe that Andy is alluding to that. Still, if you pull the leads off of the alternator and it does not blow the fuse after thirty minutes of running, that's a pretty good indicator that the problem is in the alternator. Be sure to tape off the loose leads so they don't short to ground when running.
AndyMA said:I would ask them to use a heat gun on the alternator while they are testing it to bring it up to temp. My guess is that there is some problem that is causing heat all along and that after 30 minutes the problem becomes acute.
Andy
