Chewwy
Platinum Member
- Joined
- May 5, 2015
- Messages
- 863
- Location
- Upstate SC, Near the Electric City
- Tractor
- Kubota L3240, MF 265, MF383
Thanks!!The lever uses a cable to actuate the PTO valve directly, so the switch is irrelevant to turn the PTO on or off. The switch sends signal to the dashboard, which is then used to prevent the engine from starting with the PTO engaged and also for the dashboard to know when to display PTO RPM. That's why I mentioned the switch and/or the wiring.
Unless you have the L3240 HST-3 which has a different setup and uses a PTO switch and a solenoid valve to engage the PTO. An electric over hydraulic setup.
I think you have hit the nail on the head. I was unaware the pto is engaged by a cable. The service manual is just not that clear.
After your suggestion, I went digging in the parts manual and found the PTO cable diagram.
