intek 18.5 briggs will not start
/ intek 18.5 briggs will not start #1
raderb
Taylorsville NC
craftsman 18.5 Briggs and Strattion intek
I rebuilt my 18.5 Intek Briggs and Strattion. The connecting rob broke from being to low on oil. I put it back together and it wouldn't start. I took it back apart thinking I had timing off it was correct. I have checked valves, new flywheel key and I am at a loss.
/ intek 18.5 briggs will not start #2
:welcome:
/ intek 18.5 briggs will not start #3
Well start with the three basics combustion fuel and spark.
I have good spark and the plug is wet with gas. One thing I did notice was that the fuel filter is only 1/3 full. I am not sure if that is normal.
/ intek 18.5 briggs will not start #5
Clean the plug and shoot some starting fluid in
/ intek 18.5 briggs will not start #6
Got to agree here. Shoot some carb cleaner or starting fluid into it. If it fires you have a fuel/carb problem.
If it dosent, then Spark, Timing(which you double checked) or could be valve adjustment is off. Check flywheel key,
coils installed right.
/ intek 18.5 briggs will not start #7
Following up on Sox3 - What did you set the valve clearances at?
I had to go buy a new shim set to get thin enough shims for the .004/.006 settings right on my 21HP.
/ intek 18.5 briggs will not start #8
Check the compression with the throttle open. Maybe piston size or rings installed wrong? Also,make sure valve spring not broken. don-ohio :)^)
2012 Mack CHU613 Truck, VIN # 1M1AN09Y6CM010558 (A65563)
2012 Mack CHU613...
2018 AUTOCAR XPEDITOR GARBAGE TRUCK (A63276)
2018 AUTOCAR...
Easy Lawn Hydro Seeder (A65579)
Easy Lawn Hydro...
1996 International 4700 Box Truck, VIN # 1HTSCABP2TH265415 (A65563)
1996 International...
New/Unused Quick Attach Backing/Mounting Plate (A65583)
New/Unused Quick...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
