Insulation over HVAC system in Attic
   / Insulation over HVAC system in Attic #11
Kenmac, they did install the switch. :D
Now I know what the switch does. Did not know if it killed the AC or triggered an alarm. Good to know it kills the AC since if that happens I know what to check after the breakers. :D
Thanks!
Dan
Yep, If it's wired in correctly. If both drains happed to get blocked . Water fills up to the switch & shuts off the A/C so, water doesn't run over the top of emergency drain pan & cave your ceiling in
AHHHH!!!:eek:
Guess next AC season I should turn on the AC, get into the attic and see if I can trigger the switch. Hopefully it will turn off the AC. :D The pan and drain is right over our living room. Would be noticed real quick. :eek:
Thanks,
Dan
   / Insulation over HVAC system in Attic #13
The best option would be to build an insulated, air tight enclosure around the complete unit. Keep it sealed from the attic space but as an extension of your living space. That way, the unit is in conditioned space and any loses from the unit are negligable since your not blowing air into the attic.
2000 GAL FUEL TANK (A53843)
2000 GAL FUEL TANK...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
CASE CX57C EXCAVATOR (A52705)
CASE CX57C...
