Insulated panels
/ Insulated panels #1
yanmars
Veteran Member
I have hard foam insulated panels. The insulation "looks" like expanding foam. It is metal on each side. Steel I think and not aluminum but I will check with a magnet. They are 4 inches thick. Panels up to 4 feet wide and 16 feet long. I would like to insert those between studs for insulation. The building is built on 16 inches on center with 2x6 and true 2x8s.
Leave the metal on or try to peel off? Unsure how difficult that would be. Any moisture issues if the metal is kept on. The panels came off a commercial building of some type. The edges are kind of a tongue and grove. There will be heat in the building and the studs covered with plywood. Thoughts? I have about 800 plus square feet of the product.
/ Insulated panels #2
They sound like structural type panels similar to the stress skin panels used in home building which are rigid P/U foam sandwiched between chip board. Used as a total wall and ceiling construction with splines joining the panels.
  • Good Post
Reactions: JJT
/ Insulated panels #3
probably refrigerated building panels. I have seen small garages built with those.
/ Insulated panels #4
Size of building? Do you have enough to do all the walls? Do you have sheathing on the exterior already?
I would think attaching the panels to the exterior with the splines connected with some new foam between as one option. Cutting these into 15" panels is not going to yield a tight wall, so you will need some more foam between the sides of the studs.
What part of country, hi/lo temps?
/ Insulated panels
The building is exterior sided. Vinyl siding with a thin fan fold and vapor wrap. 3 block high foundation on floating concrete slab. Western Ohio. Planned to spray the gaps with foam. The building is 26x36 with 8 foot high sidewalls on the bottom and 9 foot high on the top floor. Kind of a gambrel building. Probably more use on the second floor. Not enough to do it all. Would come closer on the bottom as it will take two thicknesses on the top floor and angled. More sun exposure on the top, the bottom has a lean to on the south side and the west has a deck attached.
/ Insulated panels #7
Those panels are pade to be the exterior wall of a steel frame industrial building. We have them on the walls of our plant. They could be attached to the girts on a pole barn or engineered steel building. Ripping them to 16" to fit your walls will be tough. If you try it, be sure to wear a respirator or N95 mask. The foam dust is not good for your lungs.
Note, you will likely use more $$$ in foam to seal the edges than if you buy R19 insulation batts.
/ Insulated panels #8
A $45 foam "gun" that takes the screw on cans and your best choice. With any luck one of those skins will be aluminum and a normal skillsaw and blade will be fine. You'll need to cut it from each side unless you can find a big worm drive saw with a 10'' blade. I've cut very thin steel like the skin would be also with a regular wood cutting carbide saw blade but the edge it leaves is rough and you will eventually want a new blade.
With your free 4" foam panels, I would definitely make the effort to use it and the little expense that you make in a foam gun and a few cans WILL BE WORTH IT 👍
Without exterior and interior control of air movement through fiberglass insulation, your pizzing in the wind!
/ Insulated panels #9
Why cut them for a storage type building? Use roll fiberglass insulation between the studs and screw the panels to the studs. Double insulated and a finished wall.
/ Insulated panels
These thoughts are all appreciated. Working on a plan. Ideas are always welcome.
/ Insulated panels
I have enough of the panels to cover the ceiling. The panels are gloss white so that will be a benefit. So there is less air leakage should one caulk the tongue and groove lightly before they are joined? I will need 5-6 inch screws or lag bolts to hold them up.
I wanted to use Rockwool above but none around and it seems a bit difficult to source. Often was used in hospitals. Also wanted some Perlite to put into concrete blocks but having trouble sourcing it also. Always something.
/ Insulated panels #12
Caulking would be good, especially working overhead jamming them nice and tightly together without a bunch of help will be hard especially if the t&g is not in perfect shape. 👍
/ Insulated panels
Getting them attached to the ceiling was a concern but perhaps a drywall lift would help the matter. I already have to bring them in from a door on the second floor as I will be unable to get most up the stairway.
/ Insulated panels #14
Without knowing exactly what the panels are and their intended use in a building construction...all you are gonna get is peoples best guesses as to how to use them.
Find out what the panels are and how they were intended to be used. If you can replicate that in your own building then great. If not.....insulate using a method known to work and not cause issues
/ Insulated panels #15
Pictures where's the pictures
/ Insulated panels #17
1/4 × 6 TimberLOK screws with a fender washer under the head may be a good choice as well. I would either caulk on the surface, or white tape used for the roll insulation on a steel frame building. Caulk in the grooves may make disassembly difficult.
/ Insulated panels #18
I vote for the ceiling use. Using a drywall jack. Lightly caulk the splices. Will make a very tight insulated ceiling that looks great.
/ Insulated panels #19
Those are walk-in cooler panels cut it with a circular saw
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2016 UTILITY 53X102 REEFER TRAILER (A59905)
2016 UTILITY...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
2005 Isuzu NQR 4 door box truck with folding gate (A61306)
2005 Isuzu NQR 4...
2019 KENWORTH DAY CAB (A59905)
2019 KENWORTH DAY...
2013 Freightliner Forest River 390BH 39ft. Class A Motorhome (A59231)
2013 Freightliner...
