Insulated doghouse project photos
   / Insulated doghouse project photos #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Here's the completed doghouse built in the cold of my barn. I brought it in the garage to paint the trim. It's for a neighbor's three beagles that I felt sorry for. I learned some things too.
I built a superinsulated sleeping compartment inside of a bigger doghouse to keep them warm in our severe winds of the flat plains I live on. It's 36" wide and 60" long with a 30" x 36" X 20" high sleeping area. I used 1 1/2 inch foam between the 1 1/2 x 2 1/2 actual dimension studs , a two by four sandwiched PT and foam base and an un-insulated area for the entry. I drilled vent holes above the sleeping compartment (attic) and a couple in the sleeping area top since the vet told me to. The dogs like it and have gone in it so, if no condensation forms inside, I'm good to go. Might have to drrill a few more holes.
I used rolled roofing and tacked and tarred the edges. This is the only way to go for a two pitch roof in the summer but shingles might have worked better in the cold. I used 3/8 T-111 type stuff on the sides. OSB inside walls. PT skids under it.
The photos show the open entry door from the tall side front. This is opposite the wind. The side door with the handles is an insulated trap door (press fit) to check on the dogs and change their bedding. The roof unit is lag bolted on but is removable to remove the superinsulated sleeping compartment top for the summer. Note here, I spent 25 years in northern Maine and understand the condensation risks of insulated buildings for animals. I hauled it over in the bucket of my JD 5520 with a strap around it.
This building is for a severe wind and cold area with no protection.
Another way to do this for lesser climates would be to build a gable type structure just big enough to hold the existing plastic doghouse you already have and just slide it in through a trap door in the gable end. Use plywood sheating for strength and I'll bet it would work and be cheaper. I spent $150.
A better way is to bring the dogs in at night and tell the wife you and the dog came as a pair. Or septuplets as in my case.
There ye be; my doghouse for my neighbor's three beagles. We are no better than the least of us. I really do feel better knowing they can take a 35 MPH cold wind with no problem.
   / Insulated doghouse project photos #2
Nice job. Maybe you answered this in your earlier post, but wouldn't it make sense to have a flap or hinged door to keep out the wind? I'm thinking like a pet door used on house doors to let dogs and cats in and out.
   / Insulated doghouse project photos #4
Very nice doghouse. So, while the dogs like it what did the neighbor say? I would think if he cares so little for the dogs that this act of kindness on your part can only be interpreted as an insult on his.
I was tactful enough to make it work. He is a nice guy but is not at home 24/7 with job and all and does the best he can. He means well and the dogs have a basic level of comfort but this will keep them out of the wind. Because he travels and is depending on others to take care of them, I don't think he knows all the details of their care. But it doesn't matter anyway. I care about the dogs and they are now taken care of. Some things you just have to do.
Regarding the open door, it may be open but it is merely to an open area and another door to their insulated room. No wind is getting in except for ventilation.
   / Insulated doghouse project photos #6
Maybe the neighbor can sleep in there when he is in the dog house with his wife?
   / Insulated doghouse project photos #7
A righteous man cares for the needs of his animal, but the kindest acts of the wicked are cruel. Proverbs 12:10
   / Insulated doghouse project photos #8
That is the nicest doghouse I've ever seen. Nice work all around!
   / Insulated doghouse project photos #9
Fantastic job, pride of construction is obvious.
Those animals will be very very comfortable and happy in their house.
What comes around, goes around.
You can sleep well knowing you've done a really good thing for animals that can not do it for themselves.
People like you make a mark, not all of us can say the same.
Sincerely,
Joel
   / Insulated doghouse project photos #10
Very nice work. If he was my neighbour SWMBO would be on my case (and his) to do the same thing -- I'm sure that knowing the Beagles are warm is very rewarding. You are a great neighbour:)
Regards
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
Mitsubishi Mini 2WD Truck  (A52384)
Mitsubishi Mini...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2013 MACK GU (GRANITE) (A52472)
2013 MACK GU...
2015 Ford F-450 Flatbed Truck (A51692)
2015 Ford F-450...
