instrument panel glass cloudy white
   / instrument panel glass cloudy white #1
4000su
Anyone have experience with your instrument panel glass turning a cloudy white color on top half and some of it looks like a dripping shapes after running at PTO RPMs for quite a while--for example brush hogging a field.
I have a JD 2740
   / instrument panel glass cloudy white #2
Condensation inside the instrument. See it all the time. It usually clears up after it warms up.
   / instrument panel glass cloudy white #3
I have a 2520, and I get some condensation during cool down after about an hour of mowing. It clears up fairly quick. Obviously, some moisture is getting in there, but I cant figure out how. It's not ideal, but I'm not too worried about it.
   / instrument panel glass cloudy white #4
My JD 4300 does that when I have been bush hogging for several hours. It really doesn't look like condensation and it is usually hot dry days when I am out mowing. The first time it happened, it looked like the plastic had gotten too hot and was permanently damaged so I was surprised when it was cleared up the next day. It doesn't cause any real problem and it does always clear up.
   / instrument panel glass cloudy white #5
I don't know about the 2x20s or the 2x40s, but the JD4x00s have a glass instrument
cover that is varnished on the inside. The varnish can go bad, as well as the rubber
gasket. On my last 4300, I took the cluster apart and used a razorblade scraper to
remove the varnish. Now, it looks like new.
A good rubber gasket should keep the humidity out.
   / instrument panel glass cloudy white #6
My 4200 had the same problem.I took the cluster apart,removed the lens,cleaned it and the gasket with rubbing alcohol and reinstalled.no more problems
   / instrument panel glass cloudy white #7
My 4300 has the same issue. Glass will cloud up and then clear as it cools. Never have taken the cluster apart, figuring I'd probably screw something up...
   / instrument panel glass cloudy white #8
Also had the same problem on a 2000 yr JD4700. The dealer was "helpful" and more than happy to sell me a replacement instrument module that "would eliminate the problem". And of course the new one clouded up just like the original. So, like everyone else, I just grinned and beared it, like most loyal JD'ers.
jim
   / instrument panel glass cloudy white #9
Hair dryer.
   / instrument panel glass cloudy white #10
Try cleaning the inside lens surface with Rain-X anti-fog or Kleer VU. As mentioned above, it's condensation and the anti-fog should solve your problem.
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
1999 CASE 721C WHEEL LOADER (A53843)
1999 CASE 721C...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2013 Chevrolet Malibu Sedan (A51694)
2013 Chevrolet...
Killbros 260 Seed Conveyor (A53473)
Killbros 260 Seed...
