Tires Instead of chains. Maxigrip Screw in tires studs.?
   / Instead of chains. Maxigrip Screw in tires studs.? #3
Interesting concept, but would it not be easier and less time consuming to use chains? unless you left them in year round....
   / Instead of chains. Maxigrip Screw in tires studs.? #4
I put screws into the lugs of the R1s on my Gravely. This was just before I got the JD 4010. Never really got to try the Gravely much with the screws in the lugs before selling it. Before, I had to put chains on the Gravely to push the snow blower. It pushed the 4' snowplow fine with dual turfs. That old square chute snow blower was a beast though.
I did it after reading herein about some putting screws into motorcycle tires and racing them on the ice.
Ralph
   / Instead of chains. Maxigrip Screw in tires studs.? #5
Years ago studded snow tires for cars were common and I can say from experience that on hard packed snow and ice they made a huge difference. I would have to think they would work much the same for tractors operating under the similar conditions.
As to them being better than chains, for all around use I don't think so.
Al
Yes its hard to beat tire chains for traction i think also. But I have a little concern about driving comfort on main roads with chains. My retired father will maybe next winter season start to clear snow for the municipality with my tractor. On walkways and smaller roads/driveways. This means he must drive on asphalt main roads quite some miles/time to get to the different places. With chains on maybe the rides will be a pain?
If I go with the lugs they will stay on year round. The Maxigrip company claim that they have tested the studs on a 19800 lbs JD for 700 hours on asphalt and not a single stud was gone after this.
Just want to check here first before I make a Swiss cheese out of my tires :)
   / Instead of chains. Maxigrip Screw in tires studs.? #7
This is not at all a new idea Gents and it is a good one at that. I was raised on the ice roads of Quebec long before the introduction of salt on road surfaces (that will tell you how old I am).... We used to install studs into our winter tires (maybe 100 per tire back then) and they worked much better and were far quieter than chains ever could. Other than being hard on pavement surface, which is why municipalities eventually banned them, the ride quality was a whole lot better than tire chains.
Also, when ice racing on motorbikes, we used to drive 2 to 300 wood screws from the inside of the tires and we would have セ of sharp pointed screws on the outside scary thought by today痴 safety standards, but we sure got going in a hurry
Dan
   / Instead of chains. Maxigrip Screw in tires studs.? #8
V-Bar Chains would be better and cheaper also.
I wanted chains on the front of my BX2660 but have a clearance problem.
I checked into the studs at my Kubota dealer but at a dollar thirty a piece I will go without.
Agco S150 Manure Spreader (A50774)
Agco S150 Manure...
Bobcat 753 Skidloader (AS IS) (A50774)
Bobcat 753...
2018 JLG 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2018 JLG 10054...
(3) Rolls of New Barb Wire (A50515)
(3) Rolls of New...
2020 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2020 CHEVROLET...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/nerve-alive-supplement-reviews-inspired-by-nervecalm-for-natural-nerv-1044754
https://www.accessn...
