Installing Winch on RTV 500
   / Installing Winch on RTV 500 #1
DIXIEDOG
Platinum Member
Maine
International 2544 / Gator 825i/L2501/General
Since I'm tighter than bark on a tree I didn't opt for the dealer to install my winch on the RTV 500 I bought so now I've got to pick one up and put it one. Besides the winch, wiring, and the roller fairlead do I need any special brackets to mount the winch to? Are there already holes in the frame to hold a winch?
   / Installing Winch on RTV 500 #2
There are mount holes above the front hitch receiver..Not sure how universal the mountings are though.
   / Installing Winch on RTV 500 #3
My Trans Mule diesel weighs in around 1700 lbs. dry so I installed a Warn RT40. The weight of your rig will dictate the winch power required. Plan on installing a winch that is at least rated double the LOADED weight of your RTV 500.
I planned on putting a 2500lb on there like the dealer does I just didn't want to pay their price for one. I wasn't sure if I needed any additional brackets or plates to install it though, I just want to have everything I need for the install before I try to put it on.
   / Installing Winch on RTV 500 #5
If the RTV 500 is anything like the RTV 900, there is a pre-drilled mounting plate under the hood. The winch and fairlead stay inside, and you pull the cable out a hole in front.
I opted to make my own adapter plate and install the winch outside on the bumper/grill ***'y. Kubota is useless in their documentation telling the owner about the drilled plate under the hood.
Good luck! My winch gets a lot of work, and I can highly recommend the synthetic line you can buy on Ebay; it's flexible, strong, doesn't stretch, and doesn't fray.
2013 Dodge Journey SXT SUV (A50324)
2013 Dodge Journey...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
2003 Pierce Tilt Cab Pumper Fire Truck (A50323)
2003 Pierce Tilt...
Toro Reelmaster 3100D Reel Mower (A50121)
Toro Reelmaster...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2016 Kenworth T270 Truck, VIN # 2NKHHM6X1GM110171 (A51572)
2016 Kenworth T270...
