installing tooth bar
   / installing tooth bar #1
moonstruck
Boone, NC
Kubota B7800
I just took delivery of a tooth bar for my TC33DA supersteer. The bolts that came with it are larger than the holes that are drilled in the sides of the bucket. I would guess there is about 1/8" difference on both sides.
Any ideas on easy ways to enlarge the holes? I hate to take the easy way and buy smaller bolts.
   / installing tooth bar #2
You have a couple of choices. You can get a a small round grinding wheel and using your die grinder or electric drill, enlarge the holes. Or you can get the correct size bi-metal hole saw and make the hole the correct size. I would vote for the bi-metal hole saw.
   / installing tooth bar #4
Do the stepdrill. That will be the easiest way to enlarge them.
murph
Thanks guys, there is a Northern Tools store about a mile from my office. I have never used a step drill but it sounds like the right tool.
moonstruck
   / installing tooth bar #6
Harbor Freight is currently offering a set of 3 different sized titanium nitride step drills for $29.99 for the set.
   / installing tooth bar #7
Go with the step drill, the hole saw won't be much good since the hole is already there. No place for the pilot bit.
ABB Rotterdam Air Compressor (A49461)
ABB Rotterdam Air...
POWER BNG2800IE INVERTER GENERATOR (A50854)
POWER BNG2800IE...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
2017 TRAILSTAR END DUMP TRAILER (A50854)
2017 TRAILSTAR END...
16 STEEL SHEETS CURVED (A50854)
16 STEEL SHEETS...
2007 John Deere TX 4x2 Utility Gator (A49346)
2007 John Deere TX...
