Installing thumb on an excavator
/ Installing thumb on an excavator #1
JimP
southern New England
Kubota L5460HSTC; Volvo ECR88 excavator; Dresser TD9H dozer; Bandit RM990 chipper (sold)
I'm not sure if this belongs in welding or construction equipment so mods feel free to move.
I have a Volvo ECR88, its about 8 tons so in between a compact and full excavator. It has a Geith coupler and I'm installing a Geith pin on hydraulic thumb. The bottom of the thumb is held to the bottom of the stick by a longer pin. At the top of the stick a hydraulic cylinder mount will be welded. There are no other attachment points between the thumb and stick.
I am getting different opinions on whether to use doubler plates on the stick. The stick is about 6 inches wide and 3/8 thick on the mount face. If I do plate I'm thinking 3/8 low carbon or HSLA steel. Plate the stick end? Under cylinder mount? The whole stick? None of the above? TIA. Jim
/ Installing thumb on an excavator #2
Always use doubler plates in high stress areas! Make sure you do not use any 90-degrees corners on the doubler plate.
/ Installing thumb on an excavator #3
Use a doubler plate. And as Shield Arc mentioned "round the corners" and weld around the corners. Do not stop or start at a corner.
I have seen many of these grappler/thumbs installed over the years, some with a doubler and some without. I have not come across one with a plate that showed any sign of dipper stick distortion, material bending, or tearing on those with a plate but have seen a few that did not have a doubler plate.
/ Installing thumb on an excavator #4
I think just mild steel plate would work. The thumb may have recommendations for welding the cylinder mount. If not, there should be lots of pics of thumbs on the internet.
Thanks guys. I should clarify that the cylinder mount ears are on a 5/8 thick mount plate (5 x 9 1/2 diamond shape). Good enough to weld to the stick? I can put a doubler between the stick and mount plate, but it would add length only as there is barely enough width to step the plates. Jim
/ Installing thumb on an excavator #6
With that mount plate no need for a doubler. Direct pull will be at the 5" sides and directly in line with the perpendicular side plates and the 9 1/2" diamond shaped length will spread any center stress out far enough.
/ Installing thumb on an excavator #8
With all this good info on welding, just to add, be sure to use a cross over relief on the thumb cyl. Even better is a work port relief that dumps to tank on the extend side [base] of the cyl. Most who do not do this end up with a bent cyl. CJ
/ Installing thumb on an excavator #9
I've always just set the circuit relief and never had any troubles
Set of 4 Unused 10-16.5N.H.S. ForeRunner Skid Steer Wheels and Tires (A66734)
Set of 4 Unused...
1 TIRE BALANCER (A66091)
1 TIRE BALANCER...
2021 JOHN DEERE 333G SKID STEER (A65056)
2021 JOHN DEERE...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
Komatsu PC138USLC Excavator (A64047)
Komatsu PC138USLC...
