Tubes INSTALLING INNER TUBES TO FLUID FILL TIRES
   / INSTALLING INNER TUBES TO FLUID FILL TIRES #1
Brown Dog
North GA
John Deere 5115M 5101E H260 5115M 540M all MFD
I had tubes installed in my Turf Tires on my JD 4720 to fill with fluid.
The tire store used cheap generic knock off brand tubes that was thin as bicycle tubes.
No Joke.
I've had 3 rear tubes & 1 front tubes to split wide open.
12+ inches.
I'm changing back to tubeless as my other two JD's are, at each failure & refilling with Fluid.
Lesson learned = ONLY USE USA MADE NAME BRAND INNER TUBES especially when filled w fluid.
You wouldn't believe the difference in thickness.
I hope this saves someone the hassle & $$ that I spent Learning the Hardway.
   / INSTALLING INNER TUBES TO FLUID FILL TIRES #2
My local tire shop couldn't find Titan tires when I needed to replace the 8 year old front tires of my JD so they supplied Carlisle. Two years later I went to another tire shop and he had new Titans for me in 3 days. A little bit more money than the Carlisles, but they last longer than two years....
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
UNUSED IRANCH 15" EXCAVATOR WOOD GRAPPLE (A54757)
UNUSED IRANCH 15"...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
2018 Doosan DL220-5 Articulated Wheel Loader (A55787)
2018 Doosan...
2016 Club Car Precedent Electric Golf Cart (A53424)
2016 Club Car...
UNUSED FUTURE MINI QUICK ATTACH PLATE (A54757)
UNUSED FUTURE MINI...
