Installing ford 4400 pto shaft.
   / Installing ford 4400 pto shaft. #1
paintma1
FORD 4400 3CYL DIESEL
I was bushoging yesterday and noticed my pto shaft was not spinning. I looked where the shaft entered the housing and fluid was pouring out. The shaft had slid out about 6 inches and destroyed the bearing. After removing the drive shaft for the bushog I pulled on the pto shaft and it pulled completely out of the housing. Am I going to have a large problem putting the shaft back in? There is a c clip ring on the shaft and there was a very fine spring partly under the c clip.Any advice would be greatly appreciated. Thanks
   / Installing ford 4400 pto shaft. #2
You ever get an answer on this? I had the very same thing happen today. Cutting/cutter stopped/ pot shaft was further out than usual/gushing fluids. I got it back to the house and when I pulled the cutter link, the whole shaft came out. It looks great, but wondering if I broke a seal, or a bearing right at the end if the housing. Planning to pull the back plate off tomorrow and see what I find.
I'm on a '65 Ford 4000 8 speed
2016 New Holland Boomer 47 4WD Front Loader Utility Tractor with Bush Hog BH16-2 (A50322)
2016 New Holland...
Unused Rhino ER10 Hay Rake (A50515)
Unused Rhino ER10...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
2013 Infiniti M37 (A50324)
2013 Infiniti M37...
2011 Chevrolet Equinox (A50324)
2011 Chevrolet...
2025 84in Dual Cylinder Grapple Bucket Skid Steer Attachment (A51691)
2025 84in Dual...
