Installing Electric To The Barn
   / Installing Electric To The Barn #71
My 32X40 barn is 100' from the house. I ran direct burial 6 (UF6AWG??) to the barn and have a breaker box installed there. In the house it's tied to a 50A breaker in my main panel. This stuff was rated at 55amps at this length. Inside the barn I have 16 lights (100 Watt) run off 4 switches and 12 plugs. Barn does have an air compressor but is made to run on 110V. Due to closeness of barn to house I didn't run water but probably should have. Swinging around 150' of garden hose gets to be a nuisance /forums/images/graemlins/smile.gif
   / Installing Electric To The Barn #72
I ran water and phoneto mine as well... ran the water, phone, and electric in3 different trenches... probably didn't have to.. but felt better ( and more exhausted ) anyway..
Soundguy
I have read all the posts, WOW a lot of great info, and this is what I plan to do, let me know if this will work, remember this is just a shed, no welding, no high power needs. I will run 200 feet (from the house breaker box to the shed) of 10/3 from a single 20 amp breaker. On one circuit, I will have 2 inside outlet plugs, one on each side of the shed, both on a GFI.. On the other circuit, I will add 2 outside 500 W lights, and 4-100w lights inside. I will run the wire in PVC 12 inches down; the wire will be direct burial type. I will run all inside wire, 14/2, in the shed inside of PVC conduit to protect it from the mice. I will run phone cable outside of the conduit, at the bottom of the conduit.
Questions
If I use schedule 80 threaded conduit pipe, can I only go 6 inches down?
What size conduit should I use with 10/3, 1 inch?
Thanks for all the TBN folks that have added to this thread. I hope I got it right.
   / Installing Electric To The Barn #74
Tom,
20 amps at 200 feet in 10 gauge will give you a voltage drop of ~7%. Thats a little high. Specs call for no more than 5%.
For 10/3 you could get by with 1/2" conduit over short runs and 3/4" for longer runs.
If it were me I would rent a trencher and run some 1-1/2" or 2" PVC at least 2 feet down. Sleeve some 8/3 as you go and glue the joints. That way you will have about 4% voltage drop and plenty of room to upgrade later if needed.
Afternoons work and a couple hundred bucks, mainly wire and trencher rental.
But then again I am always willing to help spend other peoples money.....
Fred
   / Installing Electric To The Barn #75
W/ 10/3 direct bury wire u will need 1" conduit because of width of wire.
The wire is flat and wide and may be tough to pull thru w/ conduit it would be easier to pull 4 10ga. thhn wires.
Ok after some feed back on my idea I have made the following changes:
I will use one inch rigid conduit and bury it 6 inches. I do not have to incur the cost of a ditch witch for a few hours and my lawn does not get totally messed up. I will have one straight run with only 2-90 on each end. I will also add plastic CAUTION tape on top of the conduit before I back fill and take pictures and measurements and attached it to the breaker box for the next guy to own the house.
I will use 2-20 amp single pole breakers.
I will bury the phone line in a separate PVC pipe.
I will look at the cost difference of 8 vs., 10 gauge wire.
Thanks for the comments it has helped me refine the
project.
   / Installing Electric To The Barn #77
I'd be scared to have it only 6 inches down. To easy to chop it up. What about building codes?
   / Installing Electric To The Barn #79
Agreed if you are talking UF-B.
But I would use 10/3 THHN. This is much thinner. Will work well if in a conduit.
Fred
2004 Ford E-250 Cargo Van (A50323)
2004 Ford E-250...
Stump Bucket (A50322)
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2022 BARFORD TR8036 MOBILE SCREEN (A51242)
2022 BARFORD...
2014 Chevrolet Tahoe (A50324)
2014 Chevrolet...
