Installing at 485 backhoe
   / Installing at 485 backhoe #1
poolecw
North West Georgia
How big of a job would it be to add a 485 backhoe to a 2010 3535? Would it be just a matter of buying the 485 and hooking it up or would there be a lot of dealer prep work and tractor reconfiguration?
   / Installing at 485 backhoe #2
You should be able to do it yourself, i hook my hoe by myself. You can do it.:)
   / Installing at 485 backhoe #3
I believe the backhoe has a subframe that also has to be installed on your tractor. To me, that would be dealer work. Once the subframe is installed the mounting and unmounting of the backhoe is pretty simple.
   / Installing at 485 backhoe #4
The dealer allows 11 hours for the install, and they said it takes every bit of it. Have them do it, especially if your tires are loaded.
   / Installing at 485 backhoe #5
11 hours? It is a bit of work to get the sub-frame mounted, but if a experienced installer started at 8am and was not done by noon then he was messing around or ran into an issue. I would have the dealer do it though, unless you have experience in such things. Sometimes a hole needs to be reamed a little, or bolt is the wrong length that came in the kit, or a fitting is wrong. That doesn't happen often, but often enough to create an issue. We have a hardware store of bolts, fittings, etc., so we aren't set back if we run into little snags like that.
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
2002 FREIGHTLINER FL70 DUMP TRUCK (A51406)
2002 FREIGHTLINER...
2008 Ford E-350 Altec AT200AV 30ft Bucket Van (A50323)
2008 Ford E-350...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2019 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A50324)
2019...
