Front-End Loader Installing a toothbar
   / Installing a toothbar #1
JasG
Veteran Member
CNY
B2650,
I bought a tooth bar for my Kubota with the 72" bucket. I went to install the bar and it does not fit. The inside of the bucket is 71 1/2" and the tooth bar bolt brackets are 71 3/4.
The dealer said they have to cut a lot of the down and reweld them. Is this "normal" to have to do. I would have though from other threads I have read here that they just bolt on.
The toothbar is a Tisco made bar.
   / Installing a toothbar #2
71 3/4 is correct size for a 72" bucket HOWEVER that 72 needs to be the inside measurment and if you ordered based on the bucket spec sheet, the would give you the outside dimension.
You needed to measure the inside when ordering!
However no big deal- cut and reweld. (the 'ears' dont work hard, in fact not at all, the serve only to keep the tooth bar in place.
   / Installing a toothbar #3
When I bought mine WR long brand they made me measure the inside of bucket twice while I was on phone with them
   / Installing a toothbar #4
The manufacturer of the tooth bar I bought (10 years ago) wanted the inside measurement of the bucket (as part of the ordering process). When I received it, it fit perfectly.
I suggest returning it to the manufacturer and let them fix it.
BTW, when I modified that same tooth bar (lengthened it to fit another bucket), I purposely made it a 1/4" shorter for an easy fit. I use a flat washer on either end as a spacer.
So, you might want that tooth bar a bit shorter then the inside measurement of your bucket.
   / Installing a toothbar #5
Who supplied your bucket measurement? Did you just ask your Kubota dealer to get one for you? If so, it's on them, if not, it looks like it might be on you. I don't think grinding it down 1/8" on each side is an answer as it will still bind up. I would try to swap it out with Tisco if the back and fourth shipping expense isn't too killer.
As for your dealer saying that it is "normal" to reweld a toothbar to fit? Bull----. Sounds like they got a package deal on a bunch of misfits or they blew the measurement of your bucket. JUST SAY NO! Although 1/4" off of center probably won't make any difference to the opperation of the toothbar but what if you at a later date decide to add a FEL grapple to your existing bucket? Tolerances then start to multiply in the wrong direction.
   / Installing a toothbar #6
Have a local welder remove 3/8" from the middle & get digging, that's why you bought a toothbar, right? MikeD74T
I bought the tooth bar to dig yes, but I didn't plan on cutting and welding the thing right off the bat. To me it will never be as strong as it is right now.
I bought the tooth bar the same day as the tractor, it was the dealer that ordered it while the tractor sat on his lot. I wonder myself if he originally priced me a Kubota tooth bar and then found a cheaper one. He never looked in any book but the kubota book he had on his desk.
   / Installing a toothbar #9
I bought the tooth bar to dig yes, but I didn't plan on cutting and welding the thing right off the bat. To me it will never be as strong as it is right now.[/quote]
You'd be wrong about that. Properly welded and ground the weld would be invisable & you'd never know the difference. If you were closer I'd do it for free just to show it can be done. As an alternative you could take 3/8" off one end, which is just a tab welded on now, correct? MikeD74t
   / Installing a toothbar #10
We have been a Tisco dealer since 99, and they do have the correct one for your bucket, We buy them all the time.
Have him order the next size down tooth bar.
UNUSED AGT QNT30 EXCAVATOR (A51243)
UNUSED AGT QNT30...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
(9) SHANK ALL PURPOSE PLOW (A51243)
(9) SHANK ALL...
2022 Bobcat T66 (A50120)
2022 Bobcat T66...
2016 GENIE GTH1056 TELESCOPIC FORKLIFT (A51242)
2016 GENIE GTH1056...
2015 Ford F-550 Auto Crane 4004EH 4,000LB Crane Service Truck (A51692)
2015 Ford F-550...
