Installing a return to tank line on a 4520 cab tractor
   / Installing a return to tank line on a 4520 cab tractor #1
jenkinsph
Super Star Member
somewhere usa
Deere 110tlb, 4520, x749, L130
I am building up my laser grading system for the 4520 tractor and finally have all the electronics and other parts gathered up. The new two spool valve I have is a Danfoss PVG 32 proportional model which needs to keep the return line at a low pressure. I am looking for a good place to return to tank on the tractor without restrictions. Pressure flow is not a problem as I have three rear remotes to use.
Below is a picture of an access point I am considering using #30 is a 1/2" pipe plug. It appears to be below the oil level which will reduce air entrainment in the system. My thought is I could add a hose and coupler to this point for my return line. Any suggestions would be helpful.
   / Installing a return to tank line on a 4520 cab tractor #2
As long as it is a true 1/2" plug (measures about 3/4" OD on the threads) then you should be good to go I would think. Half inch hose and couplers and you should be all set. :cool:
Thanks Brian, it is a 1/2" plug.
Anyone know what this plug and flange is for?
2012 Ford Escape XLS SUV (A50324)
2012 Ford Escape...
2021 New Holland P2350 Air Cart  New, Tow-Between, Intellirate Control, Dual Tires (A51039)
2021 New Holland...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
2006 CATERPILLAR 320CL EXCAVATOR (A51242)
2006 CATERPILLAR...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
