Installing a radio on TC40D?
   / Installing a radio on TC40D? #1
TCowner
Platinum Member
SE Minnesota
John Deere 4720 Cab
In an effort to get my twin sons (age 13) a bit more enthusiastic about the chores I am assginging them this summer using the TC40D I wanted to install the fender mounted radio I had on my JD 4600. I had made a plate that attached to the fender bracket and ROPS on the JD and it worked pretty well although I think the reception was affected a bit by the ROPS. I suppose I could buy them both a Walkman but I want them to make the connection between the music they listen to (I'm not sure you can call it music) and the tractor. Unfortunately, I can't find a good location on either side of the tractor where I don't anticipate intereference with the controls. On the JD I just had the range lever on the left side. ON the Newholland I have the range lever, pto, FWD, etc. On the right side I have the joystick and hydraulic remote controls. I don't want to keep hitting my elbow. Has anyone found a good place to install a radio?
   / Installing a radio on TC40D? #2
I understand the connection between the tractor and the radio but....
How about those hearing protectors with the built-in radio? That way their tender, young hearing will less likely be damaged.
Mark
   / Installing a radio on TC40D? #3
I installed a fender mount radio on the right fender on my nh 1920.. not sure of your fender / rops arangements. Perhaps you could find an L shaped piece of angle iron and band clamp it to a rops, and then weld a small platform on that for the radio... this moves it up a bit and keeps you from welding / drilling on the rops.
I also know they make a cannopy mounted radio, that would hang somewhere ont he underside of your cannopy ( if you have one. )
I think you would be able to mount a fender on up there, if you just popped the side swivel screws out, reversed the radio section, so it is facing the right way when in use.
Here's a couple pics of mine.
   / Installing a radio on TC40D? #4
and #2
soundguy
   / Installing a radio on TC40D? #5
Peltor Work Tunes works for me. Volume limit and noise reduction on the tractor noise.
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
2022 Caterpillar 906M Compact Articulated Wheel Loader (A56857)
2022 Caterpillar...
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
John Deere 4510 (A53317)
John Deere 4510...
2014 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
CONCORD CRE96018B CONVEYOR BELT (A52706)
CONCORD CRE96018B...
