INSTALLING A LOADER ON A DK40SE HST
/ INSTALLING A LOADER ON A DK40SE HST #1
chasemech
CONN
Ford 1520, Kioti DK40SEHST
Can someone tell me the best way to install the loader on the dk 40se hst tractor. I am having a problem lining up the two pins that hold the loader arms in place. It takes me about 30 min to install the loader. Any help would be appreciated.
/ INSTALLING A LOADER ON A DK40SE HST #2
The best way to make sure the loader installs easily starts with taking the loader off. Make sure it's on firm level ground. If the loader is not stored on firm level ground re-installation can be a bear.
When you are putting the loader back on, if you have already used the bucket curl function, use the boom cylinders to line up one pin at a time. Once you make the first pin, you should be able to use the boom cylinders again to line up the second.
If one pin is higher than the other, you need to use the bucket and the boom functions to get it to line up. Just make the low pin first, then the higher one.
Starting on level ground saves a bunch of aggrivation.
Bulk Lot - Atlas Copco Pump End Components (3) Pallets - Selling as One Lot (A63689)
Bulk Lot - Atlas...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
2024 JOHN DEERE TURF GATOR TX 4X2 UTV (A63276)
2024 JOHN DEERE...
30x57 Welding Table (A65640)
30x57 Welding...
2011 Energy Absorption Systems TMA9000 19ft Attenuator Trailer (A61572)
2011 Energy...
