Installing a 3rd SCV on My 4320
   / Installing a 3rd SCV on My 4320 #1
ChrisJD4320
Shady Grove, PA
John Deere 4320
I am making hay now and I have noticed that certain pieces of equipment require hydraulics at the rear of the tractor. I assume I will need to install the 3rd SCV kit. Has anyone done this? Is it a do it yourself kinda thing? Is a 3rd SCV enough? What equipment would use more than 1 outlet at the back? (ie neccesitating the purchase of the electric diverter thing which is expensive)
I plan to buy a tedder, haybine (or similar), rake and a small baler. I may also get a 3pt log splitter. Any input would be appreciated.
   / Installing a 3rd SCV on My 4320 #2
I would look in the hydraulic forum. this has been discussed many times.
Also you could do a seach on TBN for 3rd SCV. and you would find lots of explanations on how this is done...;)
Good Luck
Chris....:)
   / Installing a 3rd SCV on My 4320 #3
Your 4320 technically already has the 3rd SCV. When you buy the kit from JD, your getting the handle that operates the valve and the hard lines and QD's that go on the rear of the tractor.
I believe you need to take the right rear tire off to get access to the valve. If you are an average wrencher you should have no trouble.
   / Installing a 3rd SCV on My 4320 #4
ChrisJD4320: Sent you a PM...
____________________
2007 JD 5225 IOOS
542 FEL with Skid Steer Quick Attach, 72" 4in1, 72" toothbar, 72" Grapple, Stump Bucket, 48" Forks, Hay Spike, Skid Steer to 3pt. adaptor, Hydraulic Adjustable Ballast Box, Cat. 2 Auger, 70" reversible tiller, hydraulic 3pt. boom, BushHog SQ600, Horiz/Vert 3pt. 4-way log splitter
2006 Toyota Tundra 4X4 Pickup Truck (A53424)
2006 Toyota Tundra...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
SHOP FAN WELDING CART (3) JACK STANDS (A54757)
SHOP FAN WELDING...
43030 (A51691)
43030 (A51691)
14179 (A55788)
14179 (A55788)
JOHN DEERE 8R 280 (A53084)
JOHN DEERE 8R 280...
