Everything but what I need! Actually it's at dealer getting 50 hour service and getting the slow rear hydralic fall and the engine lope fixed and a strange problem with FEL joystick. When I got it to dealer the joystick worked but moved about 5 to 6 times normal distance like it had pop'ed out of socket.
Primary use so far has been for lynch and hitch pins storage. There is a pipe wrench and a 14 inch adj., Phillips and reg. screw drivers, heavy pair of pliers, heavy wire cutters (need set heavy enough to cut wire and barb wire that you pick up with bush hog.) Shear bolts for bush hog, Rotary tiller, Post hole diggers, etc, 4 lb hammer, pocket knife, various size nylon tie staps, electrical tape, duct tape, 25 ft ruler, pen and paper in a ziplock, small LED flashlight in a ziplock, cheap 2.99 VOM in ziplock. These are contained in original Mahindra toolbox and new one I added.
Would have liked to have found a slightly larger box for top fender but trying to find a substantial metal tool box with full metal piano hinge is hard. I found this one at Tractor Supply on closeout. I don't think the plastic one's will hold up long term to vibration and shock.
