Backhoe Installed a new GX690 Honda but I can't get a spark?? Any suggestions??
   / Installed a new GX690 Honda but I can't get a spark?? Any suggestions?? #1
Pacifictimes
Terramite T5C
T5c 2001 starter turns over, fuel cylenoid is energized, oil is on the high side, motor is grounded, positive battery cable hooked to the starter, turns over fine. Just NO spark??
   / Installed a new GX690 Honda but I can't get a spark?? Any suggestions?? #2
If you have it plugged into a ign switch disconnect it and just jump across the solenoid to crank it over and check your spark now almost sounds like you have a wire wrong also check and see if there is a on off switch on side of flywheel housing. Some had one some didnt without knowing the exact model i can tell for sure.
Hope this helps
Sam
WACKER NEUSON LIGHT TOWER (A55745)
WACKER NEUSON...
STEAM CLEANER (A55745)
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A57192)
2001 INTERNATIONAL...
10 GALLON SANDBLASTER (A54757)
10 GALLON...
2000 Morbark Towable Brush Chipper (A55851)
2000 Morbark...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
