Backhoe Installed a new GX690 Honda but I can't get a spark?? Any suggestions??
   / Installed a new GX690 Honda but I can't get a spark?? Any suggestions?? #1
Pacifictimes
Terramite T5C
T5c 2001 starter turns over, fuel cylenoid is energized, oil is on the high side, motor is grounded, positive battery cable hooked to the starter, turns over fine. Just NO spark??
   / Installed a new GX690 Honda but I can't get a spark?? Any suggestions?? #2
If you have it plugged into a ign switch disconnect it and just jump across the solenoid to crank it over and check your spark now almost sounds like you have a wire wrong also check and see if there is a on off switch on side of flywheel housing. Some had one some didnt without knowing the exact model i can tell for sure.
Hope this helps
Sam
10 ft Shipping Container (A55973)
10 ft Shipping...
John Deere Gator Utility Cart (A50324)
John Deere Gator...
2005 KENWORTH T800B TRI AXLE BOBTAIL KILL TRUCK (A55745)
2005 KENWORTH...
2019 John Deere 310L EP Backhoe (A53485)
2019 John Deere...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
